8ntruck 9,117 #1 Posted Tuesday at 03:04 AM (edited) Finally made time for a few days of work on our Ky property this week. 1st order of business was to wake EJ the 8N up from his extended hibernation. Suprise, suprise all 4 tires held air over the winter. He needed some antifreeze to top up the radiator. Poured the remaining couple gallons of last year's gas in the tank, reinstalled the battery, flipped the switch to on, bumped the starter button, and he started right up. Scary, really. That electronic ignition I installed last year sure is wonderful. Brakes still work, too. Good sign that it got the axle leak fixed last year. Bush hogged the roadside and the 'driveway' before things got weird. Sputter, sputter, stall. Got gas in the tank, seems to be spark. What the heck? Tools a couple hundred yards up hill - 90+ degrees. Get back with proper wrench, loosen the fuel line as carb, fuel comes out. Switch on, bump the starter button, starts right up. Drive him back up the hill and trade the bush hog for a box blade. He runs the box blade for a while, but does the sputter, sputter, stall routine a couple more times. Same fix. I've come up with 3 possibilities: Vapor lock. The fuel line does pass right over the engine. It was a hot day. Loosening the fuel line at the carb 'burped' the vapor out? Faulty shutoff valve at the tank? The fuel level was approaching the 'reserve' level. Completely opening the valve does not open the 'reserve'? Overheated coil? Again, a hot day. The coil feels about like a cup of coffee. Wasn't much cooler when the tractor restarted. I'm pretty sure thus isn't the issue. Short term fix - 5 more gallons of gas in the tank tomorrow. Long term fix - electric fuel pump? Edited Tuesday at 03:07 AM by 8ntruck 5 Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,907 #2 Posted Tuesday at 09:08 AM If all things are working, gravity feed fuel system are nice, nothing added in the system to possibly go wrong. It sounds like you have an idea on what to trouble shoot. Share this post Link to post Share on other sites
nyquil junkie 333 #3 Posted Tuesday at 09:18 AM I have a 51 8n... When it sputters out and dies then wont start, immediately check for spark. it might spark a little but it needs to throw a good spark to run. 1/4" in the open air. You might se less of a spark say on the pulled out plug or on a spark tester, but under compression it might not have enough juice to spark enough. The 8n is a low compression engine.... it takes a hot spark to get it to fire. Stick a good coil on there and see if the problem goes away. As you observe, something is happening when its hot, and that narrows it down a lot. Air bubbles in the fuel line shouldn't hurt, its keeping the bowl full thats all that matters. With low fuel in the tank, it doesnt take much tilt to stop the fuel, but if it dies on that tilt, you wont have any fuel flowing out. If it did it even w a half tank, I suspect the coil is overheating. 3 Share this post Link to post Share on other sites
8ntruck 9,117 #4 Posted Tuesday at 02:22 PM (edited) the property I'm operating on has plenty of contour, so low fuel and tilt can be an issue. I installed an electronic ignition on it last fall. No points. Has great spark. Replaced the coil at that time with the one Steiner Tractor recommended. Lack of spark is on the list, but near the bottom. Twice when I checked for fuel flow, there was none, so that goes to the top of the list. Also installed a new fuel line, carb elbow, and shut off valve at the tank last fall. Haven't been into the carb in several years, though - maybe it's time. Edited Tuesday at 02:27 PM by 8ntruck Share this post Link to post Share on other sites
peter lena 9,979 #5 Posted Tuesday at 03:03 PM @8ntruck have these in use for years, low pressure 3.5 psi , absolutely bombproof , also did , my first related fuel hose , swap out , at the the time ? fuel check valve , short clear fuel rated hose up to carb , so you can always see the standing fuel , regularly add an experiment into a service area . make it better ? easier ? worse ? low pressure is perfect for these carbs , pete , k=carbole+electric+fuel+pump&hvadid=816691941064&hvdev=c&hvexpln=67&hvlocphy=9003257&hvnetw=g&hvocijid=10299470043 Share this post Link to post Share on other sites
ebinmaine 79,843 #6 Posted Tuesday at 07:57 PM 5 hours ago, 8ntruck said: Haven't been into the carb in several years, though - maybe it's time. My experience shows me that rebuilding a carb is no longer a trouble shooting exercise. It is a scheduled maintenance item. 2 Share this post Link to post Share on other sites
8ntruck 9,117 #7 Posted Tuesday at 11:30 PM Well, I started the morning by buying 5 gallons ot ethanol free gas at $3.99.9 a gallon. Poured that into EJ and he hummed along happily all day, doing box blade and grader blade work. Late in the afternoon, I noticed an oil leak on the right rear hub. Then I pushed on the tire and discovered that the hub was loose! Got out my breaker bar and hugemoungous six point socket and proceeded to torque the hub nut. Just as it was feeling like it was pulling up tight, the torque required to turn the nut stopped increasing. Not good, but I have a new nut in stock. On closer look, the threads on the axle look buggered. The new nut did not thread on easily, so I put a second washer on to use a different section of threads and patched it back together for now. Probably will end up with a new axle and hub. 2 Share this post Link to post Share on other sites
ebinmaine 79,843 #8 Posted Tuesday at 11:33 PM 2 minutes ago, 8ntruck said: ethanol free gas at $3.99.9 a gallon That's an EXCELLENT price. 3 Share this post Link to post Share on other sites
8ntruck 9,117 #9 Posted yesterday at 04:19 AM Agree. I think I'll take 5 gallons back to Michigan later this week. 1 Share this post Link to post Share on other sites
Pullstart 70,914 #10 Posted 17 hours ago In Michigan it’s close to $6 for a gallon of ethanol free around me. Awesome price Bill! 1 Share this post Link to post Share on other sites
ebinmaine 79,843 #11 Posted 12 hours ago 4 hours ago, Pullstart said: close to $6 for a gallon of ethanol free Same in Maine Share this post Link to post Share on other sites
EB-80/8inPA 2,054 #12 Posted 8 hours ago $4.85 in centraL PA on Sunday. Speaking of: 20 hours ago, 8ntruck said: Agree. I think I'll take 5 gallons back to Michigan later this week. Does anyone happen to know if there’s limits on how many gallons your average Joe Sixpack can haul in legal containers? I assume that would be a federal not state limit? Share this post Link to post Share on other sites
1mor Project 101 #13 Posted 6 hours ago No 9n,2N,or 8N tractor ever came with any sort of fuel pump. Gravity feed is always enough if everything is clean. You fuel system starts at the gas tank. Is it clean or has it accumulated loose rust or dirt? On top of your glass bowl/shut off valve there is a standpipe with a fine screen covering it maybe an inch tall. I have had that plug up on various tractors. If I am feeling lazy or in a hurry, I might close off the fuel and remove the glass cup, gasket and screen. Remove the gas cap. Then aim my compressed air nozzle up the hole leading into the tank, blowing air as I open the valve. This reverse flushes the screen on the standpipe. It is a temporary fix cuz the debris is still floating around. Turn the valve off, clean the screen and glass bowl and reassemble. Remove the fuel line and blow it out. Remove the elbow fitting on the carburetor. It has a screen reaching into the carburetor. Blow it out. If there is no screen, replace the elbow. The carb is pretty simple, but unless you really want to rebuild it, you can probably get by just by blowing through the passages and cleaning the float bowl. Keep in mind that the float and needle and seat were designed to work with the low pressure of gravity feed. You may cause new issues with any pump. The real solution for the gas tank is take it out and clean it. I've just sloshed gas around in some then poured in a bucket along with the loose rust or dirt. I cleaned one with Simple Green. Lately I have read about using white vinegar to remove the rust. I will probably try that next time I have a problem. I hope this helps, Kent Share this post Link to post Share on other sites
