Armadilloš Ā Ā 16 #26 Posted August 11 With the 301991 switch installed the engine turns over but wonāt start. The spark plug has a good strong spark. No start using starting fluid either.Ā Since the push to start button by passes all the wiring Iām going to remove the 301991 start switch and hook the push to start button back like it was and see if the engine starts. There seems to be good compression but Iām going to get a compression tester and test compression just in case. Share this post Link to post Share on other sites
953 nut Ā Ā 69,073 #27 Posted August 11 Compression tests on a Kohler with compression release can be a bit hard to go by. The cam shaft has a feature that releases some of the compression until the engine is turning over a couple hundred rpms to make it easier to start. If it ran good before it shouldn't be a compression problem unless it was opened up or the valves adjusted. Even though the engine has good spark I would start with a new spark plug.Ā Ā Ā Ā Ā 1 Share this post Link to post Share on other sites
Armadilloš Ā Ā 16 #28 Posted August 11 (edited) I had forgot about compression release. It did run before. It has a new spark plug. Thank you. Edited August 11 by Armadilloš 1 Share this post Link to post Share on other sites
pfrederi Ā Ā 21,136 #29 Posted August 11 I would put back the old plug that was in her when she last ran...Wouldn't be the first time a new electrical thing didn't work....especially if it is a Champion they fail to fire under compression 1 2 1 Share this post Link to post Share on other sites
Armadilloš Ā Ā 16 #31 Posted August 18 Finally got back to work on the Wheelhorse. Pulled the key start. Turned engine over with wire connection from battery to solenoid. Engine started. Yay! Rechecked all the wiring and realized the ground wire attached to the 103991Ā switch wasnāt grounded. Reading the diagram for 1987 301 models the ground wire from the key switchĀ goes to the seat switch. The seat switch, when the seat is sat in, seems to not be grounded but the diagram shows another ground between the key switch and the seat switch. If that is true, is the ground for the seat switch controlled by the key switch?? Second question. It would be useful if the battery was charged when the engine is running. The diagram shows a ground and 1 hot wire for the battery. Does the battery chargingĀ circuit (if there is one) go through the key switch? Thank you diagram reading gurus for your answers. Ā Share this post Link to post Share on other sites
gwest_ca-(File Mod) Ā Ā 12,483 #32 Posted August 18 One side of the seat switch is grounded. With operator in the seat and the pto ON the switch is open so the magneto wire is not grounded and the engine runs. Operator leaves the seat the switch grounds the magneto and engine stops. If the pto is OFF the magneto ground can not get to the seat switch so engine will run operator or no operator in seat. 1 1 Share this post Link to post Share on other sites
953 nut Ā Ā 69,073 #33 Posted August 18 Your wiring on the 310-8 was designed for a battery powered ignition system and you have installed a Magnum in place of the old engine, is this correct? The safety switch wiring for a battery powered system is different than that of a magneto system. With the battery powered system the safety switches remove voltage to the coil if you leave the seat with the PTO on. With a magneto system the ignition becomes grounded if the driver gets off the seat with the PTO on. If you want to have your safety switches to work as they should the ignition switch socket needs to be changed back to the way it came from the factory, a 103990 switch and a kill relay installed or completely rewire the safety switches. Going back to theĀ 103990 and kill relay would be much easier. Ā 1 Share this post Link to post Share on other sites
Armadilloš Ā Ā 16 #34 Posted August 18 Itās clear that diagram logic is more difficult than identifying wires, tracing them out and testing for continuity. If I understand correctly the diagram just shows the seat and key switch just have a common ground. The diagram answered myĀ second question because with the key switch in the run position has the battery terminal and rectifier terminal connected. I may be slow but I get there. Thank yaāll again for all the help! Ā 1 Share this post Link to post Share on other sites
Armadilloš Ā Ā 16 #35 Posted August 18 The Wheelhorse was bought with the Kohler 14 in it. The model number decal says 2010K804 Ā indicates itās a 1987. The other number on the decal next to the model number is 22694. I suspect there was a sn on a blank place on the bottom of the decal but it is gone. Is there anyway aĀ 1987 model could it originally have come with a Kohler Magnum 14?Ā Naw. I had to change the original key switch plug wiring was for a different ignition key switch. Hmmm Will need to think on if I want to go back to a different key switch so the seat switch will work. Havenāt tested that. In testing so far the deck cut out switch works and prevents starting if the clutch is engaged with clutch handle in forward position. 1 Share this post Link to post Share on other sites
953 nut Ā Ā 69,073 #36 Posted August 18 10 hours ago, Armadilloš said: It would be useful if the battery was charged when the engine is running. The diagram shows a ground and 1 hot wire for the battery. Does the battery chargingĀ circuit (if there is one) go through the key switch? Since we have determined that your engine has the 15 amp three wire charging system the drawing in yourĀ manual is incorrect, use the drawing below. As shown the charging does go through the ignition switch and a fuse. OK, the 21-10K804 is a 310-8 from 1987 and came with a magnum engine. The 400 series offered a 14 HP engine but the fundamental electrical system is the same. The 400 would have had some idiot lights and a parking brake switch and light along with a bunch of otherwise unnecessary wires to feed the idiot lights. Looking at your drawing of the key switch socket in the first post I figured it had been a battery ignition, no telling what a previous owner did. That is in the past, lets see what we can accomplish in the future. The Seat Switch for a magnum is open with the operator in the seat and closed when you get off. the black wire goes to ground and the orange wire goes to half of the PTO switch as shown on drawing 7-13 of the attached manual. There should be a blue wire on the other terminal of that half of the PTO switch. Check these out and we will continue figuring this out one step at a time. Ā Ā Share this post Link to post Share on other sites
Armadilloš Ā Ā 16 #37 Posted August 19 Thank you for the link to the file! The Wheelhorse was bought with the Kohler m14 in it when I bought it a couple of months ago. Who knows what was done to the electrical system besides taking out the key switch and installing a push button switch? Checking the seat switch, it does have an orange wire going to the pto interlock and a black wire.Ā The black wire is routed to the areaĀ behind the key switch and has a female terminal so I will connect it to the key switch ground terminal. That seems to conflict with the diagram that shows a grounding point between the key switch and the seat switch. The key switch itself is grounded so that may take care of grounding the seat switch. There are 2 black wires routed next to the key switch combined in a single female connector. 1 wire is boltedĀ to chassisĀ and the other goes to ground the volt meter.Ā There is no place to connect the single female connector in the area that I can see so I suspect it went to the optional hour meter that I donāt have. Ā Ā The orange wire has a blue wire opposite the orange wire at the pto switch.Ā Ā This is possibly another rabbit hole. There is a push pull switch to the left if the head light switch that has nothing connected to it.Ā 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) Ā Ā 12,483 #38 Posted August 20 On 8/18/2026 at 3:00 PM, Armadilloš said: The Wheelhorse was bought with the Kohler 14 in it. The model number decal says 2010K804 Ā indicates itās a 1987. The other number on the decal next to the model number is 22694. I suspect there was a sn on a blank place on the bottom of the decal but it is gone. Is there anyway aĀ 1987 model could it originally have come with a Kohler Magnum 14?Ā Naw. I had to change the original key switch plug wiring was for a different ignition key switch. Hmmm Will need to think on if I want to go back to a different key switch so the seat switch will work. Havenāt tested that. In testing so far the deck cut out switch works and prevents starting if the clutch is engaged with clutch handle in forward position. 22694 is the serial number. The blank box below it has lost it's 4-digit Julian build date. Recorded serials so far for the model and year range from 20051 to 24472 1 Share this post Link to post Share on other sites
953 nut Ā Ā 69,073 #39 Posted August 20 12 hours ago, Armadilloš said: Ā The orange wire has a blue wire opposite the orange wire at the pto switch.Ā Ā This is possibly another rabbit hole. There is a push pull switch to the left if the head light switch that has nothing connected to it.Ā The blue wire is correct, the drawing below shows where it should go. It is the magneto kill wire, be absolutely sure that it is NEVER in contact with 12 volts. As for the pushĀ pull switchĀ Ā Ā Ā Ā Ā Ā who knows what a previous owner did. The routing of the black wires as described sounds fine. 1 Share this post Link to post Share on other sites
clueless Ā Ā 3,437 #40 Posted August 20 On 8/18/2026 at 2:00 PM, Armadilloš said: The Wheelhorse was bought with the Kohler 14 in it. The model number decal says 2010K804 Ā indicates itās a 1987. The other number on the decal next to the model number is 22694. I suspect there was a sn on a blank place on the bottom of the decal but it is gone. Is there anyway aĀ 1987 model could it originally have come with a Kohler Magnum 14?Ā Naw. I had to change the original key switch plug wiring was for a different ignition key switch. Hmmm Will need to think on if I want to go back to a different key switch so the seat switch will work. Havenāt tested that. In testing so far the deck cut out switch works and prevents starting if the clutch is engaged with clutch handle in forward position. The 1987 310-8 came with the M10 10hp Magnum engine I've owned 2, if it is truly a 1987 310-8 and has a M14 14hp on it then the engine has been swapped. If it is a 1986 or 1985 they came with the K engine (battery ignition) and at some point it was swapped with a M14 thus the push button start,Ā ether way if it is a 310 the engine has been swapped.Ā 1 Share this post Link to post Share on other sites
953 nut Ā Ā 69,073 #41 Posted August 20 6 minutes ago, clueless said: if it is a 310 the engine has been swapped.Ā Yes, and to a later model Kohler with theĀ 15 amp charging system. We will continue checkingĀ one wiring circuit at a time so the final outcome is a working system without any magic smoke being let out. 1 Share this post Link to post Share on other sites
Armadilloš Ā Ā 16 #42 Posted August 21 (edited) So, my conclusion from the information provided is a previous owner swapped the original motor out for a 14hp and rather than sort out the wiring they removed the key switch and installed a push button start switch.Ā After all the information and expertise necessary, that has been provided here, I can see why they didnāt want to sort out the wiring. The system hasnāt been tested while running because 310-8-14hp is still on blocks waiting for new deck blades. The old blades sure were a bear to get off. The past owner had used lock -tight. Hopefully will be mowing this weekend. Again, thank everyone who contributed and kept me from going bonkers. Edited August 21 by Armadilloš 1 Share this post Link to post Share on other sites
953 nut Ā Ā 69,073 #43 Posted August 21 8 hours ago, Armadilloš said: Hopefully will be mowing this weekend. Share this post Link to post Share on other sites
Armadilloš Ā Ā 16 #44 Posted August 21 Pics will be otw. 1 Share this post Link to post Share on other sites
Armadilloš Ā Ā 16 #45 Posted August 23 (edited) Ā Ā Edited August 23 by Armadilloš Share this post Link to post Share on other sites
Armadilloš Ā Ā 16 #47 Posted August 23 (edited) Still need to sort out new carb so it will idle but itās working good otherwise. Thank 953nut for preventing magic smokes and all who pitched in to support my adventure.Ā Edited August 23 by Armadilloš 2 3 Share this post Link to post Share on other sites
