WHX?? 57,541 #1 Posted Tuesday at 11:47 PM Can anyone Id this hydraulic pump or what it was used on? Any ideas what it could be used for? Not certain but probably 12 vdc. Share this post Link to post Share on other sites
adsm08 4,842 #2 Posted Tuesday at 11:51 PM Can you get a better picture of the stampings on the top? Share this post Link to post Share on other sites
WHX?? 57,541 #3 Posted Tuesday at 11:57 PM (edited) 6 minutes ago, adsm08 said: Can you get a better picture of the stampings on the top? Yeah I should have my bad. Over at the neighbors and free. Will go get it tomorrow & verify voltage. if you zoom in you can make out some of it. I'm thinkin make some kind of outside the box lift for a tractor with it. Edited Wednesday at 12:00 AM by WHX?? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,390 #4 Posted Wednesday at 12:54 AM https://masondynamics.com/products/power-units/dc-power-units/monarch-hydraulics-power-unit-dyna-might-m-500/ 1 Share this post Link to post Share on other sites
Handy Don 17,058 #5 Posted Wednesday at 01:14 AM (edited) Probablh 12v. Solenoid turns on the pump when the lever is moved to one side but not the other (see the spring.) I’d bet it was from a small dump bed truck with a single-acting cylinder. Lever one way turns on pump and lifts the bed. Lever the other way drains cylinder back to the reservoir. Dyna Might Grand Rapids Edited Wednesday at 01:27 AM by Handy Don 2 1 Share this post Link to post Share on other sites
c-series don 12,171 #6 Posted Wednesday at 01:38 AM I’ve seen many of those used as snowplow lift pumps, some had two valves if it was a power angle plow. Many were made by Monarch Hydraulics. I still have a newer version of that pump on the shelf. 1 Share this post Link to post Share on other sites
WHX?? 57,541 #7 Posted Wednesday at 02:23 AM 22 minutes ago, c-series don said: snowplow lift pumps I immediately thought of a snow plow Don. Perhaps on a dump tractor build or a sxs dump box? 43 minutes ago, Handy Don said: single-acting cylinder So it would need weight of some sort to lower. Might be a hurdle. Maybe a toggle switch to run then feed a spool valve to run a double acting cylinder? 1 Share this post Link to post Share on other sites
wallfish 20,264 #8 Posted Wednesday at 02:29 AM Jeep for a plow lift I have 2 of those bought at engine shows. Single action cylinder but a double can be used just leaving the rod side connection as a vent 1 Share this post Link to post Share on other sites
WHX?? 57,541 #9 Posted Wednesday at 11:55 AM 9 hours ago, wallfish said: Jeep for a plow lift Is it mounted on the floor next to the driver or something like that? Seems like it would be a hassle to operate anywhere else. Share this post Link to post Share on other sites
Handy Don 17,058 #10 Posted Wednesday at 01:59 PM 11 hours ago, WHX?? said: I immediately thought of a snow plow Don. Don’t know any recent plow without angle control--many I’ve seen use two single action cylinders with valve putting pressure on one and opening drain on the other. Perhaps on a dump tractor build or a sxs dump box? Yes So it would need weight of some sort to lower. Might be a hurdle. Typically the weight of the empty box is adequate to lower it. Maybe a toggle switch to run then feed a spool valve to run a double acting cylinder? Unlikely, I’d say. Why have such complicated, sequential controls? Share this post Link to post Share on other sites
wallfish 20,264 #11 Posted Wednesday at 10:38 PM 10 hours ago, WHX?? said: Is it mounted on the floor next to the driver or something like that? Seems like it would be a hassle to operate anywhere else. A "remote" handle can be connected to that hole in the handle with a rod. I only know both guys that sold them told me Jeep. I did see one of those valves before that had a switch integrated on it to activate the 12v Starter. One of the valves I have has 2 valves connected together but the rest is the same and exactly like yours 1 1 Share this post Link to post Share on other sites
c-series don 12,171 #12 Posted Thursday at 12:44 AM My first truck had one of those mounted on the inside of the fender well. Two rods ran directly from the pump and through the dashboard with knobs on them. One for up and down and the other for power angle. 2 1 Share this post Link to post Share on other sites
WHX?? 57,541 #13 Posted 2 hours ago Kinda cool ... 701 solenoid. 1 1 Share this post Link to post Share on other sites
953 nut 67,698 #14 Posted 2 hours ago Delivery trucks with a lift gate use a unit like that too. 2 Share this post Link to post Share on other sites
