Brockport Bill
32 inch side discharge mower deck question ??
Brockport Bill
can someone tell me the model part number of this mower deck in photo attached --  i am guessing its from 80s but need to find a parts site here, or on  partstree, toro site etc? ------ but need the deck model number to do so - thanks
Brockport Bill
42 minutes ago, gwest_ca said:
thanks for all the files --  i am just looking specifically for the deck model style in the photo
gwest_ca
If you have a rough estimate of the year try this.
Go into the Manuals and select "Mower decks and reel"
As soon as the page opens select "Sort by" for a drop down menu and select "Files"
Now all 663 files are placed in chronological order.
Work you way up to the 32in SD decks and they are in order of production.
gwest_ca
Another way is to take the part numbers off the corner of the 3 decals and see when and where they were used. Parts Tree will list the ipl's that have that part number.
76c12091520h
That is a 37" ( I think ) deck from a vertical shaft riding mower, only decks that used that style of spindle assy.
Edited by 76c12091520h
Ed Kennell
Yes, it looks similar to my 32".     1981    05-32YSO1
Brockport Bill
Not a 37...it's 32.
gwest_ca
What center hole do the blades have? Double-D or 3/4" round?
Ed Kennell
Product photo of New Wheel Horse Mower Deck
My 05-32YS01    deck has a different rear wheel adjuster arrangement.          BTW, it is for sale for $100.     NOS...never been on a tractor.
peter lena
@Brockport Bill   those 37,s  are  rough  for  functional  gain / improvement . major reason ?  idler pulley  , lubrication failure / incrementive belt hang up , starting a BELT BOUNCE , quickly overpowers any all ,function , gave one away  that I got in a swap  , for a regular  36"  R/D deck , very easily refitted  , with  bearing  lube change out  / up grade , CLUE ? the belt bounce on those 37,s , is showing  / telling  you what is failing . just my own experience  pete
peter lena
@Brockport Bill  done over all my decks , years ago , all communality failure ?  rough noisy  spindle and related , mule drive bearings , fix / elimination? LUCAS X-TRA HEAVY DUTY  GREASE , 550 deg  flash point , polyurea rated (  anti sling ) especially  good in pto needle cone bearing , thoroughly clean out and very lightly reapply , really enhances pto spin up, also replace the outer sealed bearing (  napa has it ) . removed every bearing  in deck spindles ,popped out seals also related mule drive bearings , clean out , brake cleaner flush , repack / seal , guess what  ? never had another  whyining , rough  bearing issue , also  went after my  mule , lever set up detail function , been bombproof  for  many years . it all basically looks the same , BUT IT DOES NOT FAIL OR WHYNE , also  my pto lever set up , does not  , have a screaming  clutch disc , spin up is smooth / quiet / easy . every stage  ENHANCED for hand off to next . used my c-85 , as test bed , then duplicated it to the other tractors , over 40 years , pete
