Brockport Bill 2,471 #1 Posted August 1 can someone tell me the model part number of this mower deck in photo attached -- i am guessing its from 80s but need to find a parts site here, or on partstree, toro site etc? ------ but need the deck model number to do so - thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,485 #2 Posted August 1 3 pages of search results in no particular order https://www.wheelhorseforum.com/search/?q=rotary 32in sd&quick=1&type=downloads_file 1 Share this post Link to post Share on other sites
Brockport Bill 2,471 #3 Posted August 1 42 minutes ago, gwest_ca said: 3 pages of search results in no particular order https://www.wheelhorseforum.com/search/?q=rotary 32in sd&quick=1&type=downloads_file thanks for all the files -- i am just looking specifically for the deck model style in the photo Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,485 #4 Posted August 2 If you have a rough estimate of the year try this. Go into the Manuals and select "Mower decks and reel" As soon as the page opens select "Sort by" for a drop down menu and select "Files" Now all 663 files are placed in chronological order. Work you way up to the 32in SD decks and they are in order of production. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,485 #5 Posted August 2 Another way is to take the part numbers off the corner of the 3 decals and see when and where they were used. Parts Tree will list the ipl's that have that part number. Share this post Link to post Share on other sites
76c12091520h 4,284 #6 Posted August 2 (edited) That is a 37" ( I think ) deck from a vertical shaft riding mower, only decks that used that style of spindle assy. Edited August 2 by 76c12091520h Share this post Link to post Share on other sites
Ed Kennell 47,281 #7 Posted August 2 14 minutes ago, 76c12091520h said: That is a 37" ( I think ) deck from a vertical shaft riding mower, only decks that used that style of spindle assy. Yes, it looks similar to my 32". 1981 05-32YSO1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,485 #8 Posted August 2 https://www.partstree.com/models/05-32xs01-toro-32-side-discharge-mower-deck-1980/ Share this post Link to post Share on other sites
Brockport Bill 2,471 #9 Posted August 2 1 hour ago, 76c12091520h said: That is a 37" ( I think ) deck from a vertical shaft riding mower, only decks that used that style of spindle assy. Not a 37...it's 32. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,485 #10 Posted August 2 What center hole do the blades have? Double-D or 3/4" round? Share this post Link to post Share on other sites
Ed Kennell 47,281 #11 Posted August 2 My 05-32YS01 deck has a different rear wheel adjuster arrangement. BTW, it is for sale for $100. NOS...never been on a tractor. 1 Share this post Link to post Share on other sites
peter lena 10,055 #12 Posted August 2 @Brockport Bill those 37,s are rough for functional gain / improvement . major reason ? idler pulley , lubrication failure / incrementive belt hang up , starting a BELT BOUNCE , quickly overpowers any all ,function , gave one away that I got in a swap , for a regular 36" R/D deck , very easily refitted , with bearing lube change out / up grade , CLUE ? the belt bounce on those 37,s , is showing / telling you what is failing . just my own experience pete 1 Share this post Link to post Share on other sites
peter lena 10,055 #13 Posted August 2 @Brockport Bill done over all my decks , years ago , all communality failure ? rough noisy spindle and related , mule drive bearings , fix / elimination? LUCAS X-TRA HEAVY DUTY GREASE , 550 deg flash point , polyurea rated ( anti sling ) especially good in pto needle cone bearing , thoroughly clean out and very lightly reapply , really enhances pto spin up, also replace the outer sealed bearing ( napa has it ) . removed every bearing in deck spindles ,popped out seals also related mule drive bearings , clean out , brake cleaner flush , repack / seal , guess what ? never had another whyining , rough bearing issue , also went after my mule , lever set up detail function , been bombproof for many years . it all basically looks the same , BUT IT DOES NOT FAIL OR WHYNE , also my pto lever set up , does not , have a screaming clutch disc , spin up is smooth / quiet / easy . every stage ENHANCED for hand off to next . used my c-85 , as test bed , then duplicated it to the other tractors , over 40 years , pete Share this post Link to post Share on other sites
