compston_family@hotmail.c
Tire tube size?
Hi guys,
What tube should I get for the tires on my 701? I'm confused by the designations on the tires.
Thanks for your help!
Mike
WHX??
What is the size on the tire?
Guessing you just have 4.
80/4.00 -8 tires?
Any  tube in that same size will work.
https://ebay.io/m/wZyJyA
I don't have it in front of me, but I looked online, and came up with 16x4.00-8, whatever that means!
M
gwest_ca
M
16" diameter and 4" wide for an 8" diameter wheel.
The 4" is the inflated width between the tread and the wheel. That can change with different widths of wheel.
953 nut
:text-yeahthat:
Your front tires would use a 4.80 / 4.00 X 8 innertube. Check the valve stem to be straight rather than curved.
WHX??
:text-yeahthat:
Coined a TR-13 stem.
Thank you very much!
M
