sqrlgtr
Xtra drain Onan
sqrlgtr
Is this just and extra oil drain plug on bottom of block and has anyone been able to snug it up without taking motor loose from frame. I fixed the drain pipe to block while I had it tore down for some much needed preventive maintenance, But I missed this one:angry-cussingblack::angry-banghead:. This is on a 520H and it is leaking some but looks like its blowed up with that drop or two of oil dripping and getting blown around :D
lynnmor
You might be able to sneak a tappet wrench in there.  It ain't a big deal to remove two of the engine mounting bolts and loosen the other two to get enough room for a conventional wrench.  Now the real question is where did that engine come from, I never saw the extra drain plug.
