Brockport Bill
what oldie wh tractor is this ?
Brockport Bill
found this oldie -- what is it - i am not familiar will older era wh? any idea vlaue? thanks, Bill
ebinmaine
Only thing I can tell for sure is that it's 1969 or earlier and a 3-speed transmission. I can't see the engine well enough to determine that. Value depends on location somewhat. Up here that would be worth $200 all day.
ri702bill
Yup - looka to be a 1965 to 1967 vintage. Not sure if the engine is original - maybe not...
Brockport Bill
would you know the model name or number?
ebinmaine
You have to get that off the tag from the tractor before it could be identified properly. There are no decals showing and the engine is a replacement so there's no way of knowing exactly what you have.
ri702bill
A FrankenHorse??
squonk
Looks like a 67 era long frame with a engine not available on it. Engine has both  a recoil and electric starter on it which I have never seen on a Kohler
Achto
Look for the ID tag. It should be on the dash support just under the dash.
oliver2-44
Do you have it home yet. :auto-biker:
  • Haha 1
