Joey baga donouts 0 #1 Posted July 12 I have a 1989 wheel horse 520H. Original wheel horse with Onan P220. I’m looking for someone to rebuild the engine. Valves and pistons. A top end job. can domineering suggest a good shop in PA NY of NJ. Also what’s a job like this cost. thanks bad a donuts Share this post Link to post Share on other sites
ri702bill 12,811 #2 Posted July 12 You may be better off repowering it with a Vanguard engine.... 1 Share this post Link to post Share on other sites
953 nut 68,503 #3 Posted July 12 I could use a bag of donuts, or at least one this morning. Onan parts are going to be very high priced and the labor cost for machining a two cylinder engine will more than likely be higher than the cost of a replacement engine. The big question is "what will you be doing with the 520?" If it is for general running around and light duty stuff a Predator Engine from Harbor Freight should do the trick. Also, will you be doing the work and do you have the tools and skill set to do an engine swap? You may want to consider the Honda V Twin from Repower Specialists. https://repowerspecialists.com/collections/wheel-horse/products/wheel-horse-520-with-onan?variant=6979132817431 1 1 Share this post Link to post Share on other sites
clueless 3,436 #4 Posted July 12 smallenginewarehouse.com (repower kit) 23hp B&S Vanguard $2248.00 free shipping as of today. You will be hard pressed to just get the top end of your Onan done for much less and you still don't have a new engine. I did a repower on a Simplicity 18hp a few years back with one of their vanguard 18hp kit, took about 2 hour with the help of a neighbor, probably less time with out the added adult beverages. It fired right up and has been running just fine for the last 4+year, also the Vanguards are easy to work on and parts are readily available. The folks at SEW are easy to work with (765-946-3812). 1 Share this post Link to post Share on other sites
davem1111 2,314 #5 Posted July 12 5 hours ago, 953 nut said: I could use a bag of donuts, or at least one this morning. Onan parts are going to be very high priced and the labor cost for machining a two cylinder engine will more than likely be higher than the cost of a replacement engine. The big question is "what will you be doing with the 520?" If it is for general running around and light duty stuff a Predator Engine from Harbor Freight should do the trick. Also, will you be doing the work and do you have the tools and skill set to do an engine swap? You may want to consider the Honda V Twin from Repower Specialists. https://repowerspecialists.com/collections/wheel-horse/products/wheel-horse-520-with-onan?variant=6979132817431 Donuts.... One of my favorite quotes from a TV show is Homer Simpson saying "Donuts: Is there anything they can't do?" I don't know about the cost of a rebuild, and I know these new engines are relatively expensive, but you are unlikely to regret the investment. I have a GT-1848 with a Honda GX610 engine, repowered by a previous owner, and I love it. My only warning would be, explore your exhaust options first. Mine had part of the hood cut out so the "stock" (?) muffler on the Honda engine could fit, but I switched this to a stack and am going to be repainting another uncut hood to put on it. (Soon, I hope). Share this post Link to post Share on other sites
lynnmor 9,010 #6 Posted July 12 One source: Kustom A local NAPA store in York, PA will do the machine work but you need to completely disassemble and reassemble, hopefully they are still in that business. Share this post Link to post Share on other sites
Bill D 3,099 #7 Posted July 12 (edited) Another option is install a Briggs Opposed Twin from a Sears tractor. Pretty easy to find. You would have to source the PTO parts from one of the used parts vendors. Edited July 13 by Bill D 1 Share this post Link to post Share on other sites
sqrlgtr 3,702 #8 Posted July 12 4 hours ago, lynnmor said: One source: Kustom A local NAPA store in York, PA will do the machine work but you need to completely disassemble and reassemble, hopefully they are still in that business. I had almost forgot they rebuild Onans. Great place to get carbs for Kohlers also, never had a problem with either of the two Ive purchased from them. A little more than the jungle or flea bay but well worth it to me, I have had not so good luck with the last two mentioned places on carbs... Share this post Link to post Share on other sites
