horseman with no horse 68 #1 Posted July 11 i guess my e clip popped out the deck lift in the frame, that and the bushing is gone, where can i get a replacement? Share this post Link to post Share on other sites
horseman with no horse 68 #3 Posted July 11 its the bushing and clip for this Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,508 #4 Posted July 12 Toro at the bottom of the page https://www.partstree.com/models/31-12k801-312-8-toro-garden-tractor-1990/hydrostatic-lift-linkage-312-h-416-h-9/ 1 Share this post Link to post Share on other sites
Lee1977 7,804 #5 Posted July 12 It's a 1/2" ID x 5/8" OD brass flange bushing. If you have hardware or Lowes or Home Depot that keeps there parts draw up tp date. it should not be hard to find 1 Share this post Link to post Share on other sites
ri702bill 13,187 #6 Posted July 12 4 hours ago, Lee1977 said: Lowes or Home Depot that keeps there parts draw up tp date Not around here!! The local Lowes fasteners section is an absolute joke. The drawers resemble a campsite after being raided by a bunch of feral rabid raccoons. And the local Home Depot "streamlined" their selection to about half the size it was 2 years ago.... marketing genius I guess. 1 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,508 #7 Posted July 12 The 1/2" E-ring will fit a 7/16" groove in a 1/2" shaft. The rings are stamped so one side has rounded edges and the other is sharp. Install the ring with the sharp side facing away from the bushing for more holding pressure. The sharp edges have less chance of being forced out of the groove. Correction - I had it backwards - fixed it. 1 Share this post Link to post Share on other sites
Ed Kennell 47,586 #8 Posted July 12 (edited) My ACE Hardware has flanged bushings and E clips in the pull out drawers. Edited July 12 by Ed Kennell 3 1 Share this post Link to post Share on other sites
Blaine 276 #9 Posted July 12 ACE is the place. 2 1 1 Share this post Link to post Share on other sites
Brockport Bill 2,479 #10 Posted July 12 i actually had the flange part of the hoodstand wear off and had to replace the hoodstand - - worse was the shaft itself was "rust welded" --- nightmare to get apart and remove Share this post Link to post Share on other sites
horseman with no horse 68 #11 Posted July 19 ace sadly only has 3/4 OD and 1/2 ID others they had were even further off TS seems the same.. any suggestions? Share this post Link to post Share on other sites
horseman with no horse 68 #12 Posted July 19 https://www.tractorsupply.com/tsc/product/bronze-flange-bearing-3-8-in-inner-dia-x-1-2-in-outer-dia-x-5-8-in-length i could be mistaken though? this is the closest i could find Share this post Link to post Share on other sites
8ntruck 9,334 #13 Posted July 19 Expensive, but McMaster-Carr should have the bushing you are looking for. Small quantities are not their strong point, but the delivery times are quick. 1 Share this post Link to post Share on other sites
