Hendricksn
520xi mower deck cutting uneven
Hendricksn
I have a 520xi with a 48" deck. I'm trying to get the deck straightened out. The only way I can get it to cut even is if the front anti scalp wheels ride on the ground which I know they shouldn't. With the rear wheels at their highest point, the blades are sitting at 2.5" from the ground. The side to side is also out of whack. The non discharge side is at 3.25" and the discharge is at 2.5". I can't level it with the adjustment because it moves the deck the wrong way. Am I missing something? Any help would be appreciated. Thanks
gwest_ca
Do you have the manual?
Pullstart
Xi decks have two hangers.  They are eye bolts I believe.  They both need to be even (and present for that matter) to hang correctly.  :handgestures-thumbupright:
Edited by Pullstart
Hendricksn
So both eye bolts are there and look even. I think the issue may be with the deck. I took the deck off and it might be in the brackets or the deck itself
Hendricksn
Hendricksn
Pullstart
Seeing weld repairs, I’d surely check to find what’s warped, or different from side to side.  It should all work in one smooth motion.
