Bv1348 0 #1 Posted July 8 I have a 42 mower deck that has oil seals underneath the mower deck pulley. I am having a time trying to be get the oil seal replaced after replacing the worn bearing. All the diagrams show a different set of parts for the ms01. Any idea where to get the new seal Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,450 #2 Posted July 9 Click on fuzzy picture in this link. That will bring up a page that includes 2 pages on the spindle updates. Click on them to enlarge. You may have newer spindle assemblies. If you need dimensions of seals I may be able to find them. Shaft size is likely 3/4". What outside diameter do you need? Share this post Link to post Share on other sites
Lee1977 7,750 #3 Posted July 9 None of the parts drawings show a bottom seal on the 65 series. I had a 75 series dech and it doesn't show the seal either. Wheel Horse may have decided it wasn't needed. I change my 75 series deck to metric assenbles some time in the late 80's; Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,450 #4 Posted July 9 Don't know if it will help but here is a list of all the decks These decks all use blades with a 3/4" center hole. 1977 model 75-42MS02 replaced by (Do not have operator manual) 1978 model 85-42MS01 (Do not have operator manual) 1979 model 95-42MS00 (Do not have operator manual) 1979 model 95-42MS01 (Do not have operator manual) 1980 model 05-42MS01 (Have operator manual) 1981-1983 model 05-42MS02 (Have operator manual) 1984 model 05-42MS03 (Have operator manual) - Last year for bearings with 3/4" ID 1985 model 05-42MS04 (Do not have operator manual) - First year for bearings with 17mm ID unless older spindles were updated. 1986-1988 model 05-42MS05 (Have operator manual) 1989 model 15-42SC01 (Do not have operator manual) 1990 model 15-42SC02 (Have operator manual) 1990-1992 model 15-42SC03 (Have operator manual) 1993-2007 and 2009-2012 model 78345 (Have operator manuals) These decks all use blades with a 3/4" center hole. Note - 17mm is .669" Share this post Link to post Share on other sites
Bv1348 0 #5 Posted July 30 Thanks for all the info on the mower deck. I found new bearings and seals Share this post Link to post Share on other sites
