Mikeymo413 0 #1 Posted 16 hours ago This is my first post so I appologize if it’s not in the right place. I am looking for a reproduction set of tie rods for a 520H. Share this post Link to post Share on other sites
Sparky-(Admin) 25,823 #2 Posted 15 hours ago Go into the vendor section of the classifieds and send a message or email to K&B Tractor. Very reputable seller. 1 Share this post Link to post Share on other sites
JCM 11,244 #4 Posted 14 hours ago @Mikeymo413 MX 338 1 Share this post Link to post Share on other sites
parsonsponyz 368 #5 Posted 13 hours ago to Red Square Share this post Link to post Share on other sites
sqrlgtr 3,147 #6 Posted 11 hours ago 5 hours ago, Mikeymo413 said: This is my first post so I appologize if it’s not in the right place. I am looking for a reproduction set of tie rods for a 520H. The 520's use the heavy-duty tie rods like a regular size tractor uses and you can find the replacement ends if the rod is still in good shape, probably find the whole tie rod also but don't know what the cost would be. The ones I have just needed the grease boots replaced because they looked so bad but everything else was still in good shape. The ones posted above are smaller and want work on the 520's. Share this post Link to post Share on other sites
Sparky-(Admin) 25,823 #7 Posted 3 hours ago 8 hours ago, sqrlgtr said: The 520's use the heavy-duty tie rods like a regular size tractor uses and you can find the replacement ends if the rod is still in good shape, probably find the whole tie rod also but don't know what the cost would be. The ones I have just needed the grease boots replaced because they looked so bad but everything else was still in good shape. The ones posted above are smaller and want work on the 520's. Good point! I think the 88 and 89 520’s just had a regular front end, not swept or heavy duty. 1990 and up had the HD and swept front end. Share this post Link to post Share on other sites
sqrlgtr 3,147 #8 Posted 1 hour ago 1 hour ago, Sparky said: Good point! I think the 88 and 89 520’s just had a regular front end, not swept or heavy duty. 1990 and up had the HD and swept front end. @Sparky I just assumed those used the heavier tie rods also but have never payed any attention to the 88, 89 years. Share this post Link to post Share on other sites
