JohnDawson738 0 #1 Posted 3 hours ago I always assumed if two belts had the same published dimensions they'd behave the same. Then I had two aftermarket belts for what should have been the same OEM replacement, and one clearly rode higher in the pulley than the other. That sent me down the rabbit hole comparing OEM cross references ( https://www.amazon.com/Mower-197253-Replacement-Husqvarna-Craftsman/dp/B0949K1453) before ordering another one. Has anyone else actually seen this, or am I overthinking it? Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,869 #2 Posted 2 hours ago Most people only sized belts based on width, i.e. 1/2, 5/8, etc., and length. There is also another measurement to consider, the groove angle. That angle on the belt will dictate how well it fits into the groove on the pulley and whether or not it will give long life. Another is the belt material, the cheaper belts will wear out faster due to inferior belt material. 3 Share this post Link to post Share on other sites
WHX?? 57,270 #3 Posted 2 hours ago (edited) Yes I have seen it and Yes you may be overthinking it. Any new belt has to "break in" to the pulley. I generally buy the blue Husky ones from TSC and I always buy one either side and run the one that fits the best. Being careful not to run them in as the ones that don't fit get taken back. Also any new belt will leave some "belt dust" from run in. Blue dust in the case of Huskies. Edited 2 hours ago by WHX?? 1 1 Share this post Link to post Share on other sites
ebinmaine 79,461 #4 Posted 2 hours ago 40 minutes ago, JohnDawson738 said: overthinking You're not overthinking it. This has been an industry issue for decades. Standards can vary slightly from company to company but also if they are using outside vendors to produce their products. Even amongst the top-tier manufacturers like Gates, manufacturing methods dictated that if you needed two or more belts for the same system, you had to order a MATCHED SET to guarantee proper fit. 1 Share this post Link to post Share on other sites
WHX?? 57,270 #5 Posted 1 hour ago One thing I have learned is of all the things you can buy/order online nowadays belts is not one of them. Guaranteed it's going to be like the proverbial box of chocolates. I have a wall of them to prove this. I suspect it's due to what EB said coupled with someone stuffing the wrong size into your box. Some even the belt just labeled wrong. 11 minutes ago, ebinmaine said: Standards can vary slightly from company to company I also generally don't go by part numbers Just the belt length and type. (3L, 4L, 5L) etc. One (ok a couple) of the files I lean on heavily when replacing a belt. Get the WH part number and cross to length. Then go to farm & barn, power center, big box or where ever and shop on length. Belts_Mower_spindle_and_drive_belt_charts.pdf WH LENGTH and WIDTH BELT LIST.txt 1 Share this post Link to post Share on other sites
Ed Kennell 46,444 #6 Posted 1 hour ago 36 minutes ago, WHX?? said: Yes I have seen it and Yes you may be overthinking it. Any new belt has to "break in" to the pulley. I generally buy the blue Husky ones from TSC and I always buy one either side and run the one that fits the best. Being careful not to run them in as the ones that don't fit get taken back. Also any new belt will leave some "belt dust" from run in. Blue dust in the case of Huskies. and to the 1 Share this post Link to post Share on other sites
ri702bill 12,365 #7 Posted 1 hour ago 33 minutes ago, ebinmaine said: Even amongst the top-tier manufacturers like Gates, manufacturing methods dictated that if you needed two or more belts for the same system, you had to order a MATCHED SET to guarantee proper fit. The exact issue when replacing the two 3/8" wide captured drive belts on a 1960's gear drive deck. Older Chrysler product cars had a matched set for the AC compressor - not exactly inexpensive... 1 Share this post Link to post Share on other sites
