FarmallFarmer09 30 #1 Posted 2 hours ago i ordered a new lever and cable from Lincoln at a-z, and theres two problems that can be fixed. Too long, and lever is not right for my dash. How do i go about trimming it to size, and making it fit on my dash 1 Share this post Link to post Share on other sites
rmaynard 17,403 #2 Posted 2 hours ago If the correct part number was used to order it, then it looks like he sent you the wrong lever. I'd ask about a replacement before trying to modify it. 2 Share this post Link to post Share on other sites
ebinmaine 79,457 #3 Posted 1 hour ago 36 minutes ago, rmaynard said: If the correct part number was used to order it, then it looks like he sent you the wrong lever. I'd ask about a replacement before trying to modify it. Lincoln doesn't have the older style available anymore. They can be modified by cutting part way down and bending the top forward. I've not tried it. This is what I am told. As to the knob, I suppose heat it up? And remove it... then reinstall. @76c12091520h Brian does have the correct style. Share this post Link to post Share on other sites
