Mikewheelhorse 0 #1 Posted July 5 Need help with locating parts for my wheelhouse engine Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,335 #2 Posted July 6 Welcome to Red Square https://www.partstree.com/models/sbv-sbv-355-tecumseh-short-block/engine-parts-list-0/ That is a short block vertical crankshaft. Do you know the original engine model? What does it power? Share this post Link to post Share on other sites
953 nut 67,317 #3 Posted July 6 What specific problem are you experiencing with the ignition system? It could be a matter of cleaning the ignition points or needing a condenser. The SBV 355 appears to be a replacement for the V 70 engine used in many models of Wheel Horse beginning in 1969. Ignition parts from the H 60 or other similar vintage Tecumseh engines would work just fine. Since the Tecumseh engines went out of production eighteen years ago you will probably need to look for aftermarket parts. The attached thread has some part numbers that may aid you in your search. 1 Share this post Link to post Share on other sites
Mikewheelhorse 0 #4 Posted July 6 Thanks for the advice engine was running well then started to die and then no spark at all Share this post Link to post Share on other sites
Mikewheelhorse 0 #5 Posted 2 hours ago What would be the timing for the spark .080 Share this post Link to post Share on other sites
