Mikewheelhorse
Sbv355 tecumseh engine coil psrts
Mikewheelhorse
Need help with locating parts for my wheelhouse engine
953 nut
:WRS:
What specific problem are you experiencing with the ignition system? It could be a matter of cleaning the ignition points or needing a condenser.
The SBV 355 appears to be a replacement for the V 70 engine used in many models of Wheel Horse beginning in 1969. Ignition parts from the H 60 or other similar vintage Tecumseh engines would work just fine. Since the Tecumseh engines went out of production eighteen years ago you will probably need to look for aftermarket parts. The attached thread has some part numbers that may aid you in your search.
Mikewheelhorse
Thanks for the advice
engine was running well then started to die and then no spark at all
