whtractors24 3,509 #1 Posted 20 hours ago I’m looking to see where a 1976 c-120 automatic original clutch return spring actually mounts? The second photo is the repair that was done at one time . Thank you Share this post Link to post Share on other sites
ri702bill 12,335 #2 Posted 12 hours ago Is that a snapped off remnant of a bolt above and behind the current location?? Maybe there was a mount there??? Share this post Link to post Share on other sites
peter lena 9,923 #3 Posted 9 hours ago @whtractors24 dare I ask ? are all movement areas , rusty or movable ? penetrant / red aerosol spray grease works wonders , pete Share this post Link to post Share on other sites
pfrederi 20,777 #4 Posted 8 hours ago It mounts inside the hood stand and is a PITA to hook up.. Probably why someone made the repair you showed 1 Share this post Link to post Share on other sites
pfrederi 20,777 #5 Posted 7 hours ago OK a couple pics of the hook up.... the hidden end of the spring goes to a hole in # 6-61 cam neutral plate Good luck If you really are into self flagellation I can send you a spring 1 Share this post Link to post Share on other sites
