whtractors24
1977 c-120 auto clutch spring
whtractors24
I’m looking to see where a 1976 c-120 automatic  original clutch return spring actually mounts? The second photo is the repair that was done at one time . Thank you
ri702bill
Is that a snapped off remnant of a bolt above and behind the current location?? Maybe there was a mount there???
peter lena
@whtractors24  dare I ask ? are all  movement  areas , rusty  or  movable ?  penetrant / red aerosol  spray grease  works wonders , pete
pfrederi
It mounts inside the hood stand and is a PITA to hook up.. Probably why someone made the repair you showed
pfrederi
OK a couple pics of the hook up.... the hidden end of the spring goes to a hole in # 6-61 cam neutral plate
Good luck  If you really are into self flagellation I can send you a spring
