Butler 2 #1 Posted yesterday at 12:19 AM (edited) Looking for help repairing the "braking" I own a used Wheel Horse 16-38 HXL. Model 71225. Looking for help repairing the "braking". Any manuals with diagrams or sites that might help? I've removed the right wheel and removed the cotter pin & brake adjusting nut. I have 2 issues 1. looks like CLUTCH/BRAKE ROD is no longer connected to the BRAKE SPRING. When I push down the PEDAL-CLUTCH/BRAKE, i can feel the CLUTCH/BRAKE ROD move but the BRAKE SPRING connected to the actuating arm doesn't move. How do I connect those? 2. Feels like the actuating pins on the "brake unit" are rusted / frozen in place. How do I remove that unit to repair or replace? (Note: actuating arm is hiding the actuating pins in this picture.) Thanks in advance. Butler Edited yesterday at 01:13 AM by Butler Share this post Link to post Share on other sites
Retired Wrencher 6,737 #2 Posted 20 hours ago (edited) Butler I am not familiar with this model. I am sure someone will come along give you help. Enjoy the site. We have lots of manuals for these tractors here. There is a lot of members going to the big show this weekend so it might take a little time for them to react to your post. Edited 20 hours ago by Retired Wrencher 1 Share this post Link to post Share on other sites
Sparky-(Admin) 25,650 #3 Posted 19 hours ago I think in your introduction post Garry posted a link to all the info on that part of your machine. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,296 #4 Posted 15 hours ago I don't understand how it is assembled https://www.partstree.com/models/71225-16-38-hxl-toro-lawn-tractor-sn-200000001-200999999-2000/hydro-transaxle-assembly-cont-2-18/ Share this post Link to post Share on other sites
Butler 2 #5 Posted 15 hours ago 6 minutes ago, gwest_ca said: I don't understand how it is assembled https://www.partstree.com/models/71225-16-38-hxl-toro-lawn-tractor-sn-200000001-200999999-2000/hydro-transaxle-assembly-cont-2-18/ Yes.... agree I found this diagram (thank you for sharing links). As you noted, I can't figure out how it is assembled. How I can remove it. I can see the parts i marked in green I am able to see the parts i marked green, including able to feel the actuating pins (#38), which are behind the lever brake (#37). But, I am stumped on how to "open it up" to get at cleaning the actuating pins (#38) and get at the brake rotor/stator (#41). Looking at possibly removing these, to open it up? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,296 #6 Posted 13 hours ago What is at the top of the flat bar? Whatever it is remove it and tap the bar off the bottom bolt. I think I can see the cotter pin hole for the adjusting nut. Tap the bottom of the bar of the threaded bolt. You have the castellated nut off of it do you not? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,296 #7 Posted 10 hours ago 4 hours ago, Butler said: Yes.... agree I found this diagram (thank you for sharing links). As you noted, I can't figure out how it is assembled. How I can remove it. I can see the parts i marked in green I am able to see the parts i marked green, including able to feel the actuating pins (#38), which are behind the lever brake (#37). I'm thinking the bar should pivot on the stud sticking out. Likely rusted solid. Apply a penetrating oil and work it off the stud which is item #39. Let us know what happens. Share this post Link to post Share on other sites
Butler 2 #8 Posted 9 hours ago (edited) 10 hours ago, gwest_ca said: What is at the top of the flat bar? Whatever it is remove it and tap the bar off the bottom bolt. I think I can see the cotter pin hole for the adjusting nut. Tap the bottom of the bar of the threaded bolt. You have the castellated nut off of it do you not? Hi- In the picture (below), I have removed the cotter pin (#135) and the castle nut (#134). The lever (#37) rotates back and forth on the stud (#39). But, the actuating pins (#38) are frozen in place. (Note: unable to see the actuating pins (#38) in above picture because there are behind the lever (#37)) The lever (#37) extends up into a slot in frame (see highlighted, below)... so i cannot pull the lever (#37) forward off the stud (#39) because it is in that slot. Also, cannot pull lever upward because of the stud (#39). The lever (#37) extends up into a slot in frame By " top of the flat bar", do you mean the lever (#37)? This spring (#2) is connected at the top of the lever (#37).... the lever is not fully drawn in this picture, but it is the item in the red box. Edited 3 hours ago by Butler Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,296 #9 Posted 8 hours ago The lever (#37) rotates back and forth on the stud (#39). So the lever is not seized to the stud. Lube it up and work it off. There can not be anything but rust holding it there. The stud should not turn because it is retained by a nylock nut. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,296 #10 Posted 6 hours ago What I would do is put castellated nut back on backwards or use a standard nut if you have one. Thread it almost all the way on - leave the stud recessed a thread or two. This will protect the threads for a hammer treatment. Use a prybar or large screwdriver to put good tension on the bottom of the bar and tap the nut. The shocks generated by the hammer may persuade the lever off. Share this post Link to post Share on other sites
Butler 2 #11 Posted 3 hours ago 5 hours ago, gwest_ca said: The lever (#37) rotates back and forth on the stud (#39). So the lever is not seized to the stud. Lube it up and work it off. There can not be anything but rust holding it there. The stud should not turn because it is retained by a nylock nut. Hi- The lever (#37) extends up into a slot in frame. Lever is not seized. It moves freely. But, it extends up into a slot in frame, so it is not able to move forward off the stud. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,296 #12 Posted 2 hours ago 1 Share this post Link to post Share on other sites
Butler 2 #13 Posted 35 minutes ago (edited) 1 hour ago, gwest_ca said: That's it! "from page 3-13 of the tractor service manual" I found that manual -- Thank you so much!!! Edited 27 minutes ago by Butler Share this post Link to post Share on other sites
