sqrlgtr 4,195 #26 Posted yesterday at 12:10 AM The last ones the tire shop done for me had to go up around 65/70psi before they seated, and they did have to break one of them down and relube to get it to seat. They were 26" 10ply though and did have tubes in them. This is them on the back of my 520H. 1 Share this post Link to post Share on other sites
Handy Don 17,696 #27 Posted yesterday at 01:51 AM 1 hour ago, sqrlgtr said: had to go up around 65/70psi before they seated....26" 10ply though Yikes. 10 ply? That’s serious tire strength. What kind of duty is that 520 called to perform? 1 Share this post Link to post Share on other sites
pfrederi 21,317 #28 Posted yesterday at 02:07 AM With 10 ply if you got them seated you wouldn't even need any air pressure. 1 Share this post Link to post Share on other sites
pfrederi 21,317 #29 Posted 23 hours ago I have one of these it beats using a cargo strap around the tire to get it to seat. Read the directions about tire size ...sent a WH front tire across the shop by mistake 2 Share this post Link to post Share on other sites
Lee1977 7,811 #30 Posted 11 hours ago I had these 23x1050x12 6 ply put on at the local tire shop. On the fourth try with the air hose at max pressure and the addition of two blasters they pop on. 1 Share this post Link to post Share on other sites
sqrlgtr 4,195 #31 Posted 11 hours ago 13 hours ago, Handy Don said: Yikes. 10 ply? That’s serious tire strength. What kind of duty is that 520 called to perform? 12 hours ago, pfrederi said: With 10 ply if you got them seated you wouldn't even need any air pressure. Really wasn't going for higher ply tires but Cheapest thing that's truer to size that I have found. I have a set of 26's and 24's but believe the 24's may just be 8 ply. They came from the jungle and are Horseshoe brand. Ive not had either set long but they do run closer to size than most other "off brand" tires Ive seen and really seem to be a real tuff tire. Share this post Link to post Share on other sites
