Toolmanbill
Tire help again
Toolmanbill
You guys helped me out last year about upgrading tires.lucky for me that I took your advice. I purchased carlstar all trail 23x8x12 tires. They worked unbelievably well. I have since purchased another wheel horse 314-8 and would like to upgrade the tires for this as well. I noticed on Amazon they have 23x10.5x12 tires from Hoosier wheel that look very similar. The carlstar are 272$ and the Hoosier tires are 161$.hate to cheap out but at 111$ difference it’s tempting.
also had plans to attend the big show on Friday . But the forecast is likely looking like rain.Thursday looks much better.is there anything going on then or should I just go Friday and dodge the raindrops?
ebinmaine
2 hours ago, Toolmanbill said:
The carlstar are 272$ and the Hoosier tires are 161$.hate to cheap out but at 111$ difference it’s ******.
I've run tires of all grades, several brands and sizes.
Are you planning on keeping this tractor?
If you know what you got from the other set and that was pleasing, get them.
If it's just for resell... maybe try the cheapos?
Handy Don
Posted (edited)
By Thursday afternoon, the show will be quite busy. Larger vendors will have had time to set up; many smaller ones as well.
Busiest day is Friday, for sure.
Weather at previous shows has included epic downpours, wilting heat, and strong winds. Come prepared and just go with it.
Edited by Handy Don
rjg854
I'd go for the cheaper tire, if they are somewhat comparable, in ply rating, and you don't mind a wider tire.
pfrederi
Unless you are running a commercial lawn service with your WH I  would bet any tire would dry rot/crack before you wore it out.
Toolmanbill
Had so much luck buying these carlstar 23x8x12 tires I wanted to buy another set for this 2001 314-8 I purchased.took them to the local Goodyear store. They told me they couldn’t mount them without putting tubes in them.since I had these mounted on my 1994 model I just assumed that someone there didn’t know what they were doing.so I took them to the shop where I had the other ones mounted.he couldn’t mount them either.eventually had to put tubes in them as well.couldn’t find any information that wheel sizes had changed.any idea where I would find that info?
My_horse
What was the reason that they couldn’t mount them?  Couldn’t get the beads to seat/seal?
Toolmanbill
Yes.couldn’t get the beads to seal.what I saw was the tire was much narrower than the wheel.
pfrederi
WH  used at least 3 different width rear rims.  5, 7 and 8.5.
Measure the distance from the center flange to the drop center edge  (see picture)  if it is about 1" you have 5 "wide rims if it is 3 you have 7 inch rims4-1/2  is 8.5 " wide rims.
This assumes they all have the same Back set (1-3/8")
I bet you have different wheels on your two tractors
Pic one is a 5" rim the other 7"
Last pic is 8.5"
Edited by pfrederi
cafoose
Last pic is 8.5"
@sqrlgtr Did you see this? Thought you'd be interested.
Toolmanbill
One tire they were able to get the bead to seal but the other tire is not quite sealed.do you think it will seal with time?I put the tires on the tractor and they have not sealed yet.or should I just replace the tires and count as a loss?I really just don’t understand as both tractors had the same size factory tires.do you think it would help to run these over inflated or under inflated?I hope I don’t have to replace these as they were almost 300$.
953 nut
Did you sand off the rust and repaint the inside of your rims before having the new tires mounted?
Toolmanbill
The rims looked like new.
953 nut
May ass well buy a tube. I have attempter overpressurizing tires and then hitting the rim all around with a plastic coated dead blow hammer and stopped the rim leak TEMPORARILY!  I have used Bead Sealer which also didn't work but made a mess of the rim    :soapbox:  plus it cost as much as a tube.
Toolmanbill
Put new tubes in.forgot to post that.still not sealed but they are holding air.
ebinmaine
9 hours ago, Toolmanbill said:
holding air.
:handgestures-thumbupright:
That's what counts!
I install tubes in ALL the tires we change or install new.
Toolmanbill
I don’t know where to go from here.spent about 270$ on these tires +50$ for tubes.tires are still not sealed on the beads.did I just get bad install?used the tractor for leaf work about two hours and tires still didn’t seal.if I decide to just get a different tire what do I buy.this tractor had 23x9.5x12 tires originally and bought 23x8x12.do I go with 23x10.5x12?there doesn’t seem to be any of the original size with an aggressive tread design that I would like to have.
ebinmaine
Can you post pics of what you got? And where they aren't sealing?
If you're still having air leakage at this point then you have a bad tube. Not tire.
Edited by ebinmaine
Correct autocorrect
pfrederi
Have you measured you rims??? If you are trying to put 23 8.50 12s on 8.5 inch rims that will be an issue.  tires need to be about 1.5" wider than the rims.  You can mount wider tires on narrow rims but the tread may not lie flat on the pavement and they look bulgy...
You keep listing your tire as 8 is it not an  8.50
Edited by pfrederi
sqrlgtr
All of my 300 series tractors had 7" wide rims and had either 23x9.50 turf's or 23x8.50 ag type tires. How much air have you put in trying to get them to seal? Soapy water is your friend also when getting the beads to pop out and seal. The Carlstar tire you have are a pretty respected tire if they are the Carlisle brand but I guess they still could have made some bad ones but doubt it. BTW I have used cheapo grease instead of soapy water but little harder to clean up.
Edited by sqrlgtr
Toolmanbill
Filled tires up to 45 pounds.put soap on the bead area.will try to get pictures up today.
oliver2-44
Use them for a while, the tire bead should gradually work further on the rim.
After that lower the pressure to maybe 15 and see how they do.
Just my thoughts.
Toolmanbill
Toolmanbill
The first picture is of tire not sealing.second picture is of the rim size where the tire is not sealed. The third picture is of my old tractor where the tires are sealed and there is no tube in.do you think I’m dealing with a defective tire or improper installation?
