Toolmanbill 44 #1 Posted June 23 You guys helped me out last year about upgrading tires.lucky for me that I took your advice. I purchased carlstar all trail 23x8x12 tires. They worked unbelievably well. I have since purchased another wheel horse 314-8 and would like to upgrade the tires for this as well. I noticed on Amazon they have 23x10.5x12 tires from Hoosier wheel that look very similar. The carlstar are 272$ and the Hoosier tires are 161$.hate to cheap out but at 111$ difference it’s tempting. also had plans to attend the big show on Friday . But the forecast is likely looking like rain.Thursday looks much better.is there anything going on then or should I just go Friday and dodge the raindrops? Share this post Link to post Share on other sites
ebinmaine 80,695 #2 Posted June 23 2 hours ago, Toolmanbill said: The carlstar are 272$ and the Hoosier tires are 161$.hate to cheap out but at 111$ difference it’s ******. I've run tires of all grades, several brands and sizes. Are you planning on keeping this tractor? If you know what you got from the other set and that was pleasing, get them. If it's just for resell... maybe try the cheapos? Share this post Link to post Share on other sites
Handy Don 17,474 #3 Posted June 23 (edited) 2 hours ago, Toolmanbill said: also had plans to attend the big show on Friday . But the forecast is likely looking like rain.Thursday looks much better.is there anything going on then or should I just go Friday and dodge the raindrops? By Thursday afternoon, the show will be quite busy. Larger vendors will have had time to set up; many smaller ones as well. Busiest day is Friday, for sure. Weather at previous shows has included epic downpours, wilting heat, and strong winds. Come prepared and just go with it. Edited June 23 by Handy Don Share this post Link to post Share on other sites
rjg854 13,359 #4 Posted June 23 4 hours ago, Toolmanbill said: Amazon they have 23x10.5x12 tires from Hoosier wheel that look very similar. The carlstar are 272$ and the Hoosier tires are 161$. I'd go for the cheaper tire, if they are somewhat comparable, in ply rating, and you don't mind a wider tire. Share this post Link to post Share on other sites
pfrederi 21,150 #5 Posted June 23 Unless you are running a commercial lawn service with your WH I would bet any tire would dry rot/crack before you wore it out. 1 1 Share this post Link to post Share on other sites
