1968Commando 172 #1 Posted 17 hours ago How hard would it be to make a clevis hitch or somthing like that, and then have it have a 2 inch receiver and then hooking this up to move snow in driveways? Or does anybody else have ideas for snowplows? 1 Share this post Link to post Share on other sites
ri702bill 12,284 #2 Posted 8 hours ago Will it work... most likely. Will it work well - probably not. You are driving over the fresh snow & packing it down before you try to scrape it off. The snow will pack up if the blade is not angled - then what??? IMHO - better off with a front blade. 5 1 Share this post Link to post Share on other sites
953 nut 66,800 #3 Posted 6 hours ago You could turn the blade around where you would be backing up pushing the snow. May want to make an appointment with a chiropractor beforehand, your neck will thank you. 1 Share this post Link to post Share on other sites
1968Commando 172 #4 Posted 6 hours ago 1 hour ago, ri702bill said: Will it work... most likely. Will it work well - probably not. You are driving over the fresh snow & packing it down before you try to scrape it off. The snow will pack up if the blade is not angled - then what??? IMHO - better off with a front blade. That makes sense, guess I’m looking into making a snow plow. Share this post Link to post Share on other sites
1968Commando 172 #5 Posted 6 hours ago 4 minutes ago, 953 nut said: You could turn the blade around where you would be backing up pushing the snow. May want to make an appointment with a chiropractor beforehand, your neck will thank you. That makes sense thank you Share this post Link to post Share on other sites
cafoose 3,738 #6 Posted 4 hours ago I have a similar four-wheeler. That's interesting for grading with it. Only thing is can it be raised and lowered? Share this post Link to post Share on other sites
1968Commando 172 #7 Posted 3 hours ago 37 minutes ago, cafoose said: I have a similar four-wheeler. That's interesting for grading with it. Only thing is can it be raised and lowered? Probably by making a clevis hitch with a receiver hitch on it, I’m going to make my own clevis hitch Share this post Link to post Share on other sites
