ianc 0 #1 Posted June 13 HI ,i am from Edinburgh ,Scotland I am asking if there are alternative cutting blades that will fit the 8-25, i may be able to get here . i see they are discontinued .what size was the center hole .thanks for any help . Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,478 #2 Posted June 13 Welcome to Red Square. Have the tractor model numbers? Started to look but see more than one blade part number --- 80-4530 and 67-0200 and there may be more. Share this post Link to post Share on other sites
ianc 0 #3 Posted June 13 Hi it is a toro 8-25 .model number 56129,serial number 0000676 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,478 #4 Posted June 13 A 1990 model but no parts list found for the 56129 - a one year only model. 1989-1990 model 56128 uses blade number 67-0200 no longer available. See where it was replaced by 67-0200-03 and (94-034 but this looks like an Oregon part number and may not be correct.) 1991-1992 model 56133 uses the same blade so have to guess that is what you need. Saw where it is 25-3/16" long measured diagonally from tip to tip. 2-5/8" wide with 5/8" center hole. I went to Oregon but can not figure out how to use the site. The Toro 80-4530 may be a recycler blade. Share this post Link to post Share on other sites
ianc 0 #5 Posted June 14 that info is great ,i will see if i get some thing over here that matches those numbers thanks for your time ian. Share this post Link to post Share on other sites
