John2189
Inner tubes
John2189
Any one know a supplier with good tubes on amazon?
kpinnc
The "AR-Pro" tubes on the jungle site are decent. I haven't had any of them yet that gave any trouble.
Go ahead and get a baby powder Shaker while you're at it and use a bunch. Makes life much simpler!
Edited by kpinnc
EB-80/8inPA
I logged in to post a tube query and this post was at the top of the stack.
This jungle deal looks attractive:
https://www.amazon.com/AR-PRO-23x8-50-12-23x9-50-12-23x10-50-12-Replacement/dp/B07S2PWNQR/ref=mp_s_a_1_1?crid=1EOQ7MDOD7V7W&dib=eyJ2IjoiMSJ9.dk19iLAlac0ongiefHJNonXejMvDLOyS2ectodfhQgMA7ojoebi2ZgZQU6LHZEP1HRwC63DWS61VqiZGvA5X8B5B26qyA9h_tLjQKDxmhq6LWlurwF3WgSePYFwezUKK5ap9-wpH3yOTmbUqwXgdZUnPxUMas1hG-EKT5LbT-slAdcFs3deWXN7h4KOMz4AgP6ziivbfWrnM9lfmpiyWCg.bQHwSR9kGAOf3DjTfJSUKipWULH7C0ClJif067DYkkk&dib_tag=se&keywords=22x7.50-12+tube&qid=1781288167&sprefix=12-22x7.5%2Caps%2C527&sr=8-1
Could anyone confirm that these tubes, though slightly oversized, will still work in a 22/7.5 tire?   TIA!
Also: any tips for jacking up a flat-tired tractor that’s sitting too low to slip a jack under?  I’d rather not pull the deck if I don't have to as that looks similarly challenging.  I’m thinking either rolling it onto a thick board or using some Rube Goldberg type of lever.
Edited by EB-80/8inPA
DLF
Over size tubes tend to fold up in smaller tires.  I wouldn't used them unless I already had them.
Lee1977
John2189
Thanks I’ll check them out.
ri702bill
Do yourself a favor - inflate the tube(s) to about 5 PSI a day or two before you actually need them to be sure they are OK... do not destroy the packaging in case they need to be returned.
I inflate the tube, place it on a flat surface and place a small piece of plywood or cardboard on top. Record the height from the surface to the top of the board with a tape measure.
Check the distance the next day - you may see a change..
Yes on the talcum powder - it lets the tube wiggle into its happy position when you inflate it.
EB-80/8inPA
Lee1977
Not finding a match in the jungle, I checked out Miller Tire, but they don’t have a 22X7.5-12 tube either.
Anybody know of a source?  TIA
kpinnc
I would search for 12x6 tubes.
