jeff w 6 #1 Posted June 12 Looking for Welch plugs for Walbro carb (WHL) 8hp Kohler. Any info appreciated! Share this post Link to post Share on other sites
jeff w 6 #3 Posted June 12 I don't know, although it's a WHL-16 stamping on it Share this post Link to post Share on other sites
jeff w 6 #4 Posted June 12 Possibly 5/16, or 7.9-8.0mm Share this post Link to post Share on other sites
ebinmaine 79,714 #5 Posted June 12 I don't have any here that small. There's a place in Washington state if I remember right. Mike's carburetor. Google search that and measure your own plugs carefully and give them a call. Share this post Link to post Share on other sites
lynnmor 8,914 #6 Posted June 12 11 minutes ago, ebinmaine said: I don't have any here that small. There's a place in Washington state if I remember right. Mike's carburetor. Google search that and measure your own plugs carefully and give them a call. Measuring the hole might be better than trying to measure a plug that has been wrecked when removed. Calipers would be best but if you have a good drill set you may be able to use that as plug gauges. 3 2 Share this post Link to post Share on other sites
jeff w 6 #7 Posted June 12 Thanks for info! I've decided to put in ultrasonic bath w/current plugs in. Have talked w others who have used that method w/excellent results. I shall find out.... Share this post Link to post Share on other sites
ebinmaine 79,714 #8 Posted June 12 1 minute ago, jeff w said: Thanks for info! I've decided to put in ultrasonic bath w/current plugs in. Have talked w others who have used that method w/excellent results. I shall find out.... Odds are good that'll be fine. I've cleaned at least a couple dozen carbs that way. I run them through the ultrasonic cleaner at least 3 to 5 cycles. Often more. When you're done with the UC - spray a whole can of brake cleaner through all the ports and orifices every which way but loose. 1 Share this post Link to post Share on other sites
Bar Nuthin 2,625 #9 Posted June 13 5 hours ago, ebinmaine said: I run them through the ultrasonic cleaner at least 3 to 5 cycles What is your preferred solution to use in your ultrasonic? 1 Share this post Link to post Share on other sites
ebinmaine 79,714 #10 Posted June 13 5 hours ago, Bar Nuthin said: What is your preferred solution to use in your ultrasonic? I've been using lacquer thinner for a few years. Seems to work good and lasts well. I do NOT use the heat cycle. I do have the thinner in a separate smaller vessel and surrounded by water in the machine. 1 Share this post Link to post Share on other sites
jeff w 6 #11 Posted June 13 Thank you for the info. I'm taking carb to someone who uses them regularly. He insists it will flush out under/behind plugs. Will see. Share this post Link to post Share on other sites
Retired Wrencher 6,792 #12 Posted June 14 On 6/12/2026 at 6:28 PM, ebinmaine said: Odds are good that'll be fine. I've cleaned at least a couple dozen carbs that way. I run them through the ultrasonic cleaner at least 3 to 5 cycles. Often more. When you're done with the UC - spray a whole can of brake cleaner through all the ports and orifices every which way but loose. every which way but loose. Nice pun there Erick. 1 Share this post Link to post Share on other sites
jeff w 6 #13 Posted June 14 Taking it 2 person who has done many ultrasonic treatments and said same as you; that should do the trick, though he felt one treatment would work. Hoping that and new kit will get my 8hp Kohler perfect again. Also, get that governor set too. Thank you, ebinmaine for your thoughts. If any issues I'll get w/you. Lastly, when removing, all it took to release the two screw mount was barely turning screwdriver, it was borderline loose ( looks like a very tight fit to get a socket on those. Will find out. 1 Share this post Link to post Share on other sites
Racinbob 13,043 #14 Posted June 15 welch plugs | McMaster-Carr Share this post Link to post Share on other sites
ebinmaine 79,714 #15 Posted June 15 21 minutes ago, Racinbob said: welch plugs | McMaster-Carr McMaster Carr offers NO aluminum plugs 2 Share this post Link to post Share on other sites
jeff w 6 #16 Posted June 15 Thank you for the reply. Share this post Link to post Share on other sites
