clintonnut 127 #1 Posted October 7, 2009 Jeff(fireman) gave me this tractor. Lots of rust but it has a good future. Jeff was also generous enough to include the mower deck and snowblade. The deck shell is in suprisingly good shape and now that I have 2 decks I can make one good one. The current plan for the 953 is to repaint the wheels and put 29x12.50x15 rear tires on it. It will also have a hopped up diesel engine installed and gas tank removed for lead weights. We will also make a fiberglass grille shell with headlight delete for it. It does roll which is a positive thing. The engine is a K321 but it is seized. Hopefully it isn't seized to bad and can be broken loose and run again. Here's the tractor next to its step brother: Here's the mower deck. You can sorta see the snowblade in the backround. Share this post Link to post Share on other sites
HorseFixer 2,013 #2 Posted October 7, 2009 Good Catch Charlie! :scratchead: Share this post Link to post Share on other sites
WHC-125 4 #3 Posted October 7, 2009 Good to see it went to a good home! :scratchead: Share this post Link to post Share on other sites
TJ 184 #4 Posted October 7, 2009 looks like a good project. :scratchead: Share this post Link to post Share on other sites
tractordave3128 0 #5 Posted October 7, 2009 you hav fun doin that.....look forward 2 seeing it when its dne haha Share this post Link to post Share on other sites
Suburban 550 28 #6 Posted October 8, 2009 Knowin' you Charlie, you'll have it up and runnin' in no time. Jeff, that was very thoughtful of you. :scratchead: Share this post Link to post Share on other sites
Indy w h 5 #7 Posted October 8, 2009 I've got a 1054 that I'm trying to get tires 4. U say that ur going to put 29/12.50/15's on it ??? Will they fit under the fenders?? All I do with mine is I go to plow days & plow dirt. Just curious. Indy Share this post Link to post Share on other sites
bell 11 #8 Posted October 8, 2009 WOOO HOOO!!! It's going to be a BEAST Charlie! :scratchead: Share this post Link to post Share on other sites
Coadster32 793 #9 Posted October 8, 2009 Diamond in the rough!! :scratchead: Share this post Link to post Share on other sites
Michcruiser60 0 #10 Posted October 8, 2009 They make a nice pair. I like to find one more myself later, when the other projects get finished. One of my favorites. Mich60 Share this post Link to post Share on other sites
dkopp 1 #11 Posted October 8, 2009 What kind of diesel are you going to drop in that machine? Share this post Link to post Share on other sites
Gerry w 2 #12 Posted October 8, 2009 Looks like a before and after shot within the same frame! Nice looking rig, and quite nice barn too! Share this post Link to post Share on other sites
clintonnut 127 #13 Posted October 9, 2009 It's funny you said that Ray! I actually took the head off the engine and got it freed up. Would like to get it running this weekend. I think the 12.50 tires will fit under it. Today my dad and I decided to change the rear half of the tractor. Since the fenders are completly rotted out we are going to remove them and install GT-14 fenders to accomidate the larger tires. We might put Simplicity 9020 tires on it. Where the gas tank is we are going to put barbell mounts. Also the engine is going to be moved back 8 inches. The gas tank will be placed in the battery box (smaller tank) I would like to find a Yanmar 10-12hp diesel for it. Charlie Share this post Link to post Share on other sites
clintonnut 127 #14 Posted October 9, 2009 I am on chat if anyone wants to talk Charlie Share this post Link to post Share on other sites
clintonnut 127 #15 Posted October 15, 2009 Made some progress today. I removed the stuck exhaust valve and put a good one out of a K301 in. These engines are notorious for bent valves. Put the head on and now have compression. The tractor is also back on 4 shoes again. Since I got the ag tires for the 1054, I put the GT-14 rims that were prevously on the 1054 onto the 953. The original tank is unfortunatley rusty but I might experiment with electrolysis and lime away later. Tomorrow I am going to add a temporary gas tank, wire the ignition and get it running hopefully. Charlie Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #16 Posted October 15, 2009 These engines are notorious for bent valves. Huh? Hmmmmm...... It must be a "first generation" 321 if you put a 301 exhaust valve in it. Share this post Link to post Share on other sites
nylyon-(Admin) 8,291 #17 Posted October 15, 2009 Looking forward to the pics (64) Share this post Link to post Share on other sites
KeithB 6 #18 Posted October 15, 2009 Good deal,. nice project :scratchead: Share this post Link to post Share on other sites
clintonnut 127 #19 Posted October 15, 2009 I was also wondering if someone could give me a good explanation on the ignition setup. It is battery powered ignition but it doesn't have the external points. Could someone explain how it should be hooked up? I do have the correct coil that is the same as the ones used on the electro 12's etc. Charlie Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #20 Posted October 15, 2009 I was also wondering if someone could give me a good explanation on the ignition setup. It is battery powered ignition but it doesn't have the external points. At NO TIME should 12VDC be hooked to ANY wire on the Kohler breakerless (solid state) ignition system. It is powered by a third wire (A.C.) from a special stator and is grounded (like a conventional magneto ignition) to kill the spark. Kohler manual TP-2379 has a great description/explanation of this ignition system starting on page 8.4 Share this post Link to post Share on other sites
clintonnut 127 #21 Posted October 16, 2009 Well I did some work on the engine today. I can't get a spark. I tested the coil resistance and it is perfect. There were two yellow wires coming out of the engine. They are seperate from the stator wires. I ran a wire from the coil through a kill switch and to one of the two wires. No spark. tested the other wire, No Spark. Is there some kind of external ignition thingy I am missing? Do I need to pull the flywheel and check it out? Charlie Share this post Link to post Share on other sites
clintonnut 127 #22 Posted October 16, 2009 I got some pictures of the engine. It's just too cold to work in the barn right now. There are two wires on the left side of the engine (blue connectors) and two stator wires on the right side that are hooked to the regulator connector(wrapped around dipstick) Here's a current picture of the tractor. I took the grille shell off to service the exhaust valve. Carburetor is good. Engine has some sort of knock when you turn it over. I hope it's not internal . Share this post Link to post Share on other sites
clintonnut 127 #23 Posted October 17, 2009 Still looking for an answer to yesterdays question. Charlie Share this post Link to post Share on other sites
nylyon-(Admin) 8,291 #24 Posted October 17, 2009 I should have looked at the engine a little closer when it was here. On the coil, what wires are connected to it? I see the high tension, and only 1 other wire. Share this post Link to post Share on other sites
poodle 0 #25 Posted October 18, 2009 I would Kill for a 953 or 1054 your a lucky lucky man! Share this post Link to post Share on other sites
