Bar Nuthin 3,350 #1 Posted June 8 (edited) I didn't realize my main mower deck was so noisy until I put an older deck on a tractor I was selling and gave it a test run. The old deck was almost whisper quiet. So, I pulled my main deck and sure enough the center spindle was spinning rough and growling at me. I had a bit of a fight getting the pulley off but finally got it apart. Just waiting on some NOS bearings that I found on eBay. Question is - what is this part? Flat washer? O-ring? - There appeared to be the slightest remnants of an O-ring, but hard to tell for sure. Edited June 8 by Bar Nuthin Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,508 #2 Posted June 8 Different size deck but sounds like the same condition. Two page service bulletin 1 Share this post Link to post Share on other sites
cleat 9,380 #3 Posted June 8 I have been installing an O ring at that location since I noticed that some come with it. The grease coming up to the pulley might help keep it from seizing on though. 1 Share this post Link to post Share on other sites
Bill D 3,167 #4 Posted June 8 I never use that oring. Don't see the point. As for bearings, I use Japanese 6203 bearings I found online. 1 Share this post Link to post Share on other sites
Bar Nuthin 3,350 #5 Posted June 8 3 hours ago, gwest_ca said: Different size deck but sounds like the same condition. Two page service bulletin Thank you! That was spot on! Share this post Link to post Share on other sites
peter lena 10,087 #6 Posted June 8 @Bar Nuthin since converting my mower deck spindles over to , lucas green chassis grease, have never had any noise or related failures , typically all related bearings are 6203 type , with easily removed side shields , same bearings in , mule drive , BTW was just at a local small repair shop , had a 55 gal drum full of frozen pulleys , chinese , fish oil lube , he was doing a similar , bearing lubrication upgrade , was instantly on the same problem elimination mode . my mule drive does not scream / struggle to get things moving , never wore out a disc , that entire set up is a GOLD MINE , FOR IMPROVEMENTS . every movement stage , needs functional detailing , starting at battery tray lever start ? years in on this , quiet , smooth , easy , VERIFY EVERY STAGE , PETE 1 Share this post Link to post Share on other sites
