jeff w 7 #1 Posted May 31 Looking for Drive Belt 7473. Can't seem to find. Prefer Wheel Horse original if possible! Share this post Link to post Share on other sites
jeff w 7 #3 Posted May 31 I thought all Wheel Horse belts were black... I guess not Thank You Share this post Link to post Share on other sites
953 nut 69,787 #4 Posted May 31 https://www.tractorsupply.com/tsc/product/huskee-v-belt-5-8-in-x-82-in-oc-4461826?crmid=6663814901&utm_source=google&utm_medium=pmax&utm_campaign=tsc0_sea_tsc_cat_search_sch_us_cvr&utm_content=sku_na&adtype=pla&campaignid=22258948701&device=c&product_channel=local&product_id=4461826&store_code=219&gad_source=1&gad_campaignid=22269431188&gbraid=0AAAAADnTm22UZvSpQ8pj4maCyQlqKSlNk&gclid=CjwKCAjwuO_QBhAWEiwAIkVhU7_99doRSGJJTPdZmuEHJCVzsRZSEpC8LvfLOo7L3OVO7ie05XZ-1RoCLF8QAvD_BwE 1 1 Share this post Link to post Share on other sites
peter lena 10,087 #5 Posted June 1 @ 953nut big fan of T/S ARAMID BELTS ! changed over to those long ago , been bombproof , related to that , regularly refer to belt fraying , related wear ? thats showing / telling you of related pulley , spindle , idler lubrication breakdown failure ? on mt 3 units , every related belt pully bearing has been converted over to lucas xtra hd green chassis grease ? 550 deg flash point , polyurea , stays with bearing , what a concept ! mule drive and deck spindles , also did my pto inner needle bearing , very lightly , my related belt easily turns over the deck drive , by hand , this is a GOLD MINE FOR IMPROVEMENT ! also did my pto lever start set up ? looking right at it , every related FUNCTIONAL STAGE , was enhanced / verified , years in use , no failures , pete Share this post Link to post Share on other sites
mrc 1,119 #6 Posted June 2 jeff w the white belts were wh's attempt to lessen the jerkiness when you let out the clutch. at least that is what i recall from many years ago. Share this post Link to post Share on other sites
