Eric W in AR
My first Wheel Horse
ebinmaine
:text-welcomeconfetti: from another Eric.
You've managed to trip over one of the most desirable and best worker models Wheelhorse made.
:handgestures-thumbupright:
6 hours ago, Eric W in AR said:
clean the carb
Best idea here is to clean the WHOLE fuel system.
Remove, clean, and replace the tank, ALL rubber fuel line, filter, pump, and of course carburetor.
Check the carb top shaft for excessive wear.
For parts:
1. Place an ad in our classifieds.
2. PM @76c12091520h Brian.
3. CALL Lincoln at A to Z Tractor in PA.
There are several other places to get general maintenance items.
Wish me luck.
Luck!
:lol:
  • Like 4
SylvanLakeWH
rjg854
:text-welcomeconfetti:  2   :rs: The C-161 is a great machine, and that 16 hp is a beast.  Enjoy your time bringing up to snuff, it will be well worth it.  A wet sanding and a coat of Flood finish should be all it needs if you like a patina finish.  It's only original once.  ;)
pfrederi
Welcome...sounds like you have a lot of projects.  The Wheel Horse will serve you well
oliver2-44
:text-welcomeconfetti:Looks like a fairly straight tractor.
Thanks for sharing it some love..
With it having set outside, these transmission get water in them from a rotten/missing shifter boot.
The transmission has a hump in the middle of the bottom, so when you drain & flush it raise the front end up as high as you safely can t get it to drain completely.
Any 80/90 gear lube is good, I use the Walmart variety.
I have a points cover. and I'll check for an air cleaner cover, but I suspect I only have small ones.
Edited by oliver2-44
Razorback
Welcome!!!
Little Flock!!!!! I'm in Bentonville (4 doors north of 8th & Tunbridge)....... we need to meet sometime.
  • Excellent 2
ineedanother
Nice find and a really good model to have around. This is probably the most common source for major damage to a manual transmission. Definitely take a look at this.
953 nut
:WRS:
Good introduction, sounds like you have a lot of good background you can share with us.                  :handgestures-thumbupright:
kpinnc
22 hours ago, Eric W in AR said:
I was given a C-161 with the 8 speed
Tractor looks like it spent a few summers here in NC!
You did well finding a 161. They are not very common. :thumbs:
Achto
:WRS:
Pullstart
Welcome!  I saw a band one time named Little Flock… I wondered where that name came from :handgestures-thumbupright:
Eric W in AR
19 hours ago, Razorback said:
Welcome!!!
Sounds good, we are less than 6 miles from each other.  Have you been out to the Tired Iron of the Ozarks club shows?  I'm a member of that club and we just had our spring show in April, our fall show is in September. You should bring your tractors out to show them off.
Eric W in AR
That's great info.  I'll definitely get that changed soon.
Retired Wrencher
:WRS:        Eric if you become a supporter of this site, you can post all the pictures you want. It’s only 20 bucks a year cheap price for the pleasure that you get. Good luck with your project and enjoy the ride when it’s done.
Edited by Retired Wrencher
gwest_ca
On 5/30/2026 at 11:51 PM, Eric W in AR said:
If you are looking for the ID plate it may be here facing the engine. Interested in knowing what is on it.
Eric W in AR
I'll get a close up of that ID tag and post it here.
Eric W in AR
Here's my tag.
