Redtickuleez 6 #1 Posted 4 hours ago Was moving a load and it suddenly will not move Share this post Link to post Share on other sites
oliver2-44 11,487 #2 Posted 3 hours ago Check you idler pulley to make sure it has belt tight and the transmission drive pulley, maybe it lost its key. Also check that your axles are tight to the hub and not rotating while the hub stays still. 1 Share this post Link to post Share on other sites
peter lena 9,886 #3 Posted 3 hours ago @Redtickuleez probable opportunity ? idler pulleys are known for lubrication failure and typical undersize bearings , do a complete functionality check for every related belt hand off direction , a lot of my problem elimination is based on REPEDITIVE FAILURE . look over every stage , pete Share this post Link to post Share on other sites
pfrederi 20,565 #4 Posted 3 hours ago 3 minutes ago, peter lena said: @Redtickuleez probable opportunity ? idler pulleys are known for lubrication failure and typical undersize bearings , do a complete functionality check for every related belt hand off direction , a lot of my problem elimination is based on REPEDITIVE FAILURE . look over every stage , pete There are no idler pulleys or pulleys of any kind in a D series drive train 2 Share this post Link to post Share on other sites
pfrederi 20,565 #5 Posted 3 hours ago (edited) 1 hour ago, Redtickuleez said: Was moving a load and it suddenly will not move Does the mid mount or 3 pt lift function? Does teh motion control seem to move OK (Linkages on Ds are a night mare. Also make sure tow valve is tightly closed. Edited 3 hours ago by pfrederi 1 Share this post Link to post Share on other sites
pfrederi 20,565 #6 Posted 3 hours ago (edited) paint a line across the hub and axle on each side then after you try to move make sure they haven't shifted. D series have very hefty axle key but they can shear. Does the engine labor at all when yo try to move??? Edited 3 hours ago by pfrederi 1 Share this post Link to post Share on other sites
pfrederi 20,565 #7 Posted 2 hours ago (edited) Can you push the tractor with tow valve closed? Edited 2 hours ago by pfrederi Share this post Link to post Share on other sites
squonk 46,597 #8 Posted 2 hours ago I'm thinking the coupler might have stripped 3 Share this post Link to post Share on other sites
pfrederi 20,565 #9 Posted 2 hours ago 37 minutes ago, squonk said: I'm thinking the coupler might have stripped Could be that is why I asked if the lift still worked if it doesn't then coupler failure is top of the list. 2 Share this post Link to post Share on other sites
