Redtickuleez 6 #1 Posted Thursday at 02:34 PM Was moving a load and it suddenly will not move Share this post Link to post Share on other sites
oliver2-44 11,495 #2 Posted Thursday at 03:05 PM Check you idler pulley to make sure it has belt tight and the transmission drive pulley, maybe it lost its key. Also check that your axles are tight to the hub and not rotating while the hub stays still. 1 Share this post Link to post Share on other sites
peter lena 9,893 #3 Posted Thursday at 03:32 PM @Redtickuleez probable opportunity ? idler pulleys are known for lubrication failure and typical undersize bearings , do a complete functionality check for every related belt hand off direction , a lot of my problem elimination is based on REPEDITIVE FAILURE . look over every stage , pete Share this post Link to post Share on other sites
pfrederi 20,609 #4 Posted Thursday at 03:36 PM 3 minutes ago, peter lena said: @Redtickuleez probable opportunity ? idler pulleys are known for lubrication failure and typical undersize bearings , do a complete functionality check for every related belt hand off direction , a lot of my problem elimination is based on REPEDITIVE FAILURE . look over every stage , pete There are no idler pulleys or pulleys of any kind in a D series drive train 3 2 Share this post Link to post Share on other sites
pfrederi 20,609 #5 Posted Thursday at 03:38 PM (edited) 1 hour ago, Redtickuleez said: Was moving a load and it suddenly will not move Does the mid mount or 3 pt lift function? Does teh motion control seem to move OK (Linkages on Ds are a night mare. Also make sure tow valve is tightly closed. Edited Thursday at 03:38 PM by pfrederi 3 Share this post Link to post Share on other sites
pfrederi 20,609 #6 Posted Thursday at 03:41 PM (edited) paint a line across the hub and axle on each side then after you try to move make sure they haven't shifted. D series have very hefty axle key but they can shear. Does the engine labor at all when yo try to move??? Edited Thursday at 03:42 PM by pfrederi 3 Share this post Link to post Share on other sites
pfrederi 20,609 #7 Posted Thursday at 03:46 PM (edited) Can you push the tractor with tow valve closed? Edited Thursday at 03:48 PM by pfrederi Share this post Link to post Share on other sites
squonk 46,652 #8 Posted Thursday at 03:48 PM I'm thinking the coupler might have stripped 3 2 Share this post Link to post Share on other sites
pfrederi 20,609 #9 Posted Thursday at 04:27 PM 37 minutes ago, squonk said: I'm thinking the coupler might have stripped Could be that is why I asked if the lift still worked if it doesn't then coupler failure is top of the list. 3 Share this post Link to post Share on other sites
Redtickuleez 6 #10 Posted Sunday at 05:11 PM Where’s the idler pulley….. im sorry.. I’ve never worked on anything, mechanically speaking.. but I got no way to haul it and friends and not dependable as they once were.. so dumb it down for me please and thanks..words can’t express my gratitude for each and every reply to my topic… how do I inspect something if I don’t kno what I’m lookin at……lol Share this post Link to post Share on other sites
pfrederi 20,609 #11 Posted Sunday at 05:46 PM There are no idler pulleys First question Did the 3 pt hitch or mid mount operate while you had it running? If they did work next question Can you push the tractor with tow valve closed...Yes or no? After you answer these 2 questions we can proceed with diagnosis 1 Share this post Link to post Share on other sites
Redtickuleez 6 #12 Posted 6 hours ago On 5/31/2026 at 1:46 PM, pfrederi said: There are no idler pulleys First question Did the 3 pt hitch or mid mount operate while you had it running? If they did work next question Can you push the tractor with tow valve closed...Yes or no? After you answer these 2 questions we can proceed with diagnosis I never used it.. I don’t think… the loader and the backhoe worked fin On 5/28/2026 at 11:38 AM, pfrederi said: Does the mid mount or 3 pt lift function? Does teh motion control seem to move OK (Linkages on Ds are a night mare. Also make sure tow valve is tightly closed. e Share this post Link to post Share on other sites
Redtickuleez 6 #13 Posted 6 hours ago You’ll have to excuse my ignorance about whats what’s what… the valve is closed tightly.. I turned it to push it outta the way but then I tightened it back… im disgusted… about this… im eagerly anticipating your reply Share this post Link to post Share on other sites
pfrederi 20,609 #14 Posted 1 hour ago The loader and backhoe are run off a separate pump. Not relevant to you problem. Can you push the tractor if you close the tow valve. Share this post Link to post Share on other sites
