Redtickuleez 6 #1 Posted May 28 Was moving a load and it suddenly will not move Share this post Link to post Share on other sites
oliver2-44 11,847 #2 Posted May 28 Check you idler pulley to make sure it has belt tight and the transmission drive pulley, maybe it lost its key. Also check that your axles are tight to the hub and not rotating while the hub stays still. 1 Share this post Link to post Share on other sites
peter lena 10,125 #3 Posted May 28 @Redtickuleez probable opportunity ? idler pulleys are known for lubrication failure and typical undersize bearings , do a complete functionality check for every related belt hand off direction , a lot of my problem elimination is based on REPEDITIVE FAILURE . look over every stage , pete Share this post Link to post Share on other sites
pfrederi 21,342 #4 Posted May 28 3 minutes ago, peter lena said: @Redtickuleez probable opportunity ? idler pulleys are known for lubrication failure and typical undersize bearings , do a complete functionality check for every related belt hand off direction , a lot of my problem elimination is based on REPEDITIVE FAILURE . look over every stage , pete There are no idler pulleys or pulleys of any kind in a D series drive train 3 2 Share this post Link to post Share on other sites
pfrederi 21,342 #5 Posted May 28 (edited) 1 hour ago, Redtickuleez said: Was moving a load and it suddenly will not move Does the mid mount or 3 pt lift function? Does teh motion control seem to move OK (Linkages on Ds are a night mare. Also make sure tow valve is tightly closed. Edited May 28 by pfrederi 3 Share this post Link to post Share on other sites
pfrederi 21,342 #6 Posted May 28 (edited) paint a line across the hub and axle on each side then after you try to move make sure they haven't shifted. D series have very hefty axle key but they can shear. Does the engine labor at all when yo try to move??? Edited May 28 by pfrederi 3 Share this post Link to post Share on other sites
pfrederi 21,342 #7 Posted May 28 (edited) Can you push the tractor with tow valve closed? Edited May 28 by pfrederi Share this post Link to post Share on other sites
squonk 48,427 #8 Posted May 28 I'm thinking the coupler might have stripped 3 2 Share this post Link to post Share on other sites
pfrederi 21,342 #9 Posted May 28 37 minutes ago, squonk said: I'm thinking the coupler might have stripped Could be that is why I asked if the lift still worked if it doesn't then coupler failure is top of the list. 3 Share this post Link to post Share on other sites
Redtickuleez 6 #10 Posted May 31 Where’s the idler pulley….. im sorry.. I’ve never worked on anything, mechanically speaking.. but I got no way to haul it and friends and not dependable as they once were.. so dumb it down for me please and thanks..words can’t express my gratitude for each and every reply to my topic… how do I inspect something if I don’t kno what I’m lookin at……lol Share this post Link to post Share on other sites
pfrederi 21,342 #11 Posted May 31 There are no idler pulleys First question Did the 3 pt hitch or mid mount operate while you had it running? If they did work next question Can you push the tractor with tow valve closed...Yes or no? After you answer these 2 questions we can proceed with diagnosis 1 Share this post Link to post Share on other sites
Redtickuleez 6 #12 Posted June 2 On 5/31/2026 at 1:46 PM, pfrederi said: There are no idler pulleys First question Did the 3 pt hitch or mid mount operate while you had it running? If they did work next question Can you push the tractor with tow valve closed...Yes or no? After you answer these 2 questions we can proceed with diagnosis I never used it.. I don’t think… the loader and the backhoe worked fin On 5/28/2026 at 11:38 AM, pfrederi said: Does the mid mount or 3 pt lift function? Does teh motion control seem to move OK (Linkages on Ds are a night mare. Also make sure tow valve is tightly closed. e Share this post Link to post Share on other sites
Redtickuleez 6 #13 Posted June 2 You’ll have to excuse my ignorance about whats what’s what… the valve is closed tightly.. I turned it to push it outta the way but then I tightened it back… im disgusted… about this… im eagerly anticipating your reply Share this post Link to post Share on other sites
pfrederi 21,342 #14 Posted June 3 The loader and backhoe are run off a separate pump. Not relevant to you problem. Can you push the tractor if you close the tow valve. Share this post Link to post Share on other sites
Redtickuleez 6 #15 Posted June 3 Yes. Ive removed the transmission and finally opened it. Where can i aquire those roller pins. ??? Share this post Link to post Share on other sites
pfrederi 21,342 #16 Posted June 3 (edited) Those are needles from failed needle bearings. You are going to have to completely dissemble the transaxle to find out which bearing failed. Looking at the size it is one of the closed end needle bearing in the case, Edit depending on the year of your D it may be the needle bearing on the end of the differential (at least one year used it instead of the 1533 ball bearing) Do you have the sunstrand manual?" Edited June 3 by pfrederi Share this post Link to post Share on other sites
Redtickuleez 6 #17 Posted June 11 On 6/3/2026 at 1:36 PM, Redtickuleez said: Yes. Ive removed the transmission and finally opened it. Where can i aquire those roller pins. ??? Share this post Link to post Share on other sites
Redtickuleez 6 #18 Posted June 11 On 5/28/2026 at 12:27 PM, pfrederi said: Could be that is why I asked if the lift still worked if it doesn't then coupler failure is top of the list. I dont kno how to use this website. Are you on FB Share this post Link to post Share on other sites
Redtickuleez 6 #19 Posted June 11 On 6/3/2026 at 1:59 PM, pfrederi said: Those are needles from failed needle bearings. You are going to have to completely dissemble the transaxle to find out which bearing failed. Looking at the size it is one of the closed end needle bearing in the case, Edit depending on the year of your D it may be the needle bearing on the end of the differential (at least one year used it instead of the 1533 ball bearing) Do you have the sunstrand manual?" Where can i find that Share this post Link to post Share on other sites
Redtickuleez 6 #20 Posted June 11 God someone pleaae HELP ME. FRIEND ME ON FACEBOOK. THIS SITE IS TOO HARD FOR ME TO NAVIGATE.. Jerry Presley. Someone please Share this post Link to post Share on other sites
pfrederi 21,342 #21 Posted June 11 Click on the fuzzy transmission picture above it will take to the manual to download. Sorry I do not do Facebook. Share this post Link to post Share on other sites
