Rick8814 1 #1 Posted May 19 Hey yall! I have a 1989 312-8. The trans axle fluid is milky. Does anyone know where the drain plug is to drain and put new in? Thanks Rick Share this post Link to post Share on other sites
pfrederi 20,819 #2 Posted May 19 Drain plug bottom of tranny you need a 1/4" hex (allen) bit 3 1 Share this post Link to post Share on other sites
ol550 863 #3 Posted May 19 And someone will be along shortly to let you know to jack up the front so the transmission will drain over the hump in the bottom. 3 2 Share this post Link to post Share on other sites
Handy Don 16,908 #4 Posted May 19 1 hour ago, Rick8814 said: and put new in? Your transaxle has a dipstick, slow filling through that is one option. Some guys lube the gearshift lever, slide the boot up, loosen the dog screw, remove the shifter (it was in Neutral, right?) and fill there. If the boot is in bad shape, it the perfect opportunity to replace it! 4 1 Share this post Link to post Share on other sites
WHX?? 57,273 #5 Posted May 19 The drain might be plugged with gunk so clean it all off good before trying to take it out. Make sure the allen gets a good bite so you don't strip it out. It might come out hard. 2 2 Share this post Link to post Share on other sites
Rick8814 1 #6 Posted May 19 Ty all very much. Next question on this 312-8. Im having a heck of time reconnecting the choke linkage. I have the kohler manual for this engine, but it doesn't show a very good picture of the choke linkage to the little bracket attached on the other side is the choke cable. Thank you in advance Rick Share this post Link to post Share on other sites
Handy Don 16,908 #7 Posted May 20 (edited) 1 hour ago, Rick8814 said: a very good picture of the choke linkage Please take a picture of what you have so we can be specific. Lots of variations out there, including well-intentioned previous owners! Edited May 20 by Handy Don 1 Share this post Link to post Share on other sites
Rick8814 1 #8 Posted May 20 Ty all very much. Next question on this 312-8. Im having a heck of time reconnecting the choke linkage. I have the kohler manual for this engine, but it doesn't show a very good picture of the choke linkage to the little bracket attached on the other side is the choke cable. Thank you in advance Rick Share this post Link to post Share on other sites
Rick8814 1 #9 Posted May 20 21 minutes ago, Handy Don said: Please take a picture of what you so we can be specific. Lots of variations out there, including well-intentioned previous owners! I definitely will ty Share this post Link to post Share on other sites
ineedanother 2,511 #10 Posted May 20 Just a word to help you along...you're in the transmission section asking about the choke linkage. You will likely have more success here, lots of folks willing to help, if you separate issues and look for solutions where you're most likely to get the most appropriate attention and responses. 1 Share this post Link to post Share on other sites
