mudmowerdiesel
More pictures of the diesel wiring
mudmowerdiesel
Almost done with the wiring
  • Excellent 2
ineedanother
love the project but wire nuts are a no-go in my shop. Enemies in the wire :tools-hammerdrill:
  • Like 7
mudmowerdiesel
Lol 😆 🤣 😂 😹 😆
953 nut
Wire nuts are for interior wiring, they will come loose from vibration.           :twocents-02cents:
mudmowerdiesel
What to use instead of wire nut
WHX??
True but :lol:
  • Haha 2
  • Heart 1
WHX??
@Achto prefers scotch locks :lol: but I prefer to solder western union splices and shrink wrap or properly crimped butt connectors.
Edited by WHX??
  • Haha 2
702854boy
I've had good luck with just a plain old butt connector with the heat shrink casing on it
oliver2-44
I've been using these heat shrink splices that have solder in them.  They are the "Cats Meow"!
But it does take a good hot heat gun to get it hot enough to melt the solder in them.
https://www.amazon.com/gp/product/B073RMRCC3/ref=ewc_pr_img_1?smid=ANYCM9RSLDH7Y&th=1
Edited by oliver2-44
SylvanLakeWH
I've used wire nuts in the past and shot silicone caulk into the connector... locks up the connection, waterproof, and was what I had on hand... never had an issue going on 5 years winter plowing... :hide:
kpinnc
OMG those are designed for solid conductor wire, not stranded.
I've been using these as well. Pretty neat concept for a butt splice. But yes they have to get pretty hot to flow the solder.
A good soldering iron and heat shrink are still best.
I use crimp on contacts but I remove the plastic sleeve beforehand and solder them and use shrink wrap to seal out the elements. Never had a wiring failure. :thumbs:
Edited by kpinnc
Andy N.
This little heat gun was worth the money when I was putting together the WH Snow Trooper project. I use the heat shrink splices and then cover them with black heat shrink.
https://www.amazon.com/dp/B08BK3M6YW?ref=ppx_yo2ov_dt_b_fed_asin_title
I've also used Wago lever connectors in a pinch.
I used marine style connectors for connections into the control boxes. This kept the controllers mostly water proof.
Pullstart
I love the build, but just wish it was all on one thread.  Just imagine a build thread for this entire project, one that was from start to finish.  It would be so much easier to find later on for reference, or sharing, etc.
mudmowerdiesel
I wish i know how to do that
Pullstart
Just respond to your previous post, there’s no need for a new topic every time :handgestures-thumbupright:
