702854boy 1,129 #101 Posted September 14 Is it getting spark? Is the wiring for all of the safety switches good? Is the coil getting power? Share this post Link to post Share on other sites
Bill D 3,121 #102 Posted September 14 Run a jumper directly from the battery positive to the coil positive, then crank it and see if you have spark. Is the ignition module connected correctly? If you connect it backwards you'll fry it. The condenser connects to the positive terminal on an Onan. This smoothes out voltage spikes that can fry the ignition module. 2 Share this post Link to post Share on other sites
953 nut 68,898 #103 Posted September 14 Have you tested the ignition module trigger? Share this post Link to post Share on other sites
WHX?? 57,941 #104 Posted September 15 Not to hijack Paul's thread. Getting ready to bench run a 220 Red lead & condenser to coil positive from pickup. Black lead to negative. Does one need to ground coil negative post to the engine block? Share this post Link to post Share on other sites
Bill D 3,121 #105 Posted September 15 47 minutes ago, WHX?? said: Not to hijack Paul's thread. Getting ready to bench run a 220 Red lead & condenser to coil positive from pickup. Black lead to negative. Does one need to ground coil negative post to the engine block? No, just ground the engine. Battery + to red wire, and battery + to starter solenoid to crank. 1 Share this post Link to post Share on other sites
WHX?? 57,941 #106 Posted September 15 Thanks Bill. Now following with interest as I can't get any spark from my bench test motor. Coil test readings match almost exactly what Paul's do. Ignition module passes manual specified test. 12 volts direct to coil from battery. Share this post Link to post Share on other sites
PWL216 1,278 #107 Posted 9 hours ago Update… Still won’t start. No spark. changed flywheel and new key new coil and condenser new spark plugs new coil wires It has 12v at the coil with the key on. There are a couple of suggestions above that I need to try. Share this post Link to post Share on other sites
lynnmor 9,028 #108 Posted 7 hours ago 1 hour ago, PWL216 said: Update… Still won’t start. No spark. changed flywheel and new key new coil and condenser new spark plugs new coil wires It has 12v at the coil with the key on. There are a couple of suggestions above that I need to try. From the Demystification Guide: Share this post Link to post Share on other sites
sqrlgtr 3,813 #109 Posted 5 hours ago ignition/trigger module? sorry if its been mentioned I have read this thread but it's been a day or two since...... 1 Share this post Link to post Share on other sites
WHX?? 57,941 #110 Posted 3 hours ago I found my no spark problem. Turns out I had spark after all it was just very very dim or dare I say weak. Checking in the dark is the only way I could see it. Just the plugs laying on the block. Screwed it down to the bench with a IV bottle and she ran like a champ. A miss at throttle but most likely dirty carb. 2 Share this post Link to post Share on other sites
Bill D 3,121 #111 Posted 2 hours ago (edited) 52 minutes ago, WHX?? said: I found my no spark problem. Turns out I had spark after all it was just very very dim or dare I say weak. Checking in the dark is the only way I could see it. Just the plugs laying on the block. Screwed it down to the bench with a IV bottle and she ran like a champ. A miss at throttle but most likely dirty carb. Consider making new, solid core, plug wires for it. I do this on all my Onans. Any video of it running? Edited 2 hours ago by Bill D Share this post Link to post Share on other sites
WHX?? 57,941 #112 Posted 1 hour ago 23 minutes ago, Bill D said: Any video of it running? I did but it came out crappy. I should do new plug wires might be the cause of the miss too. Not gonna worry about it for now since it's just a spare motor for a 520 or future build tractor. Will super tune it when the time comes. I have this crazy notion to put it in a plow mule. 1 Share this post Link to post Share on other sites
