tractorhogg 656 #1 Posted 11 hours ago Without up and done stops and the pivot bracket in the right position the center link will hit the rear panel in the up or rod out position and the pivot bracket will hit the hose and cylinder in the down position, any ideas? Share this post Link to post Share on other sites
tractorhogg 656 #2 Posted 10 hours ago Okay I adjust the rear lift brackets (screwed them in) and it no longer hits the outside panel, this may solve the down position as well as unless i push the rear lift cylinder down hard enough to slightly raise the the rear of the tractor (bad for traction). It really appears now that the fluid weeping is still coming from the swivel union I attempted to epoxy. I think putting the new NOS hose on will fix my issues, fingers crossed. BTW, after looking at the manual the pivot bracket doesn;t need to be turned around, but I still may flip it upside down after I see where the bracket hits the hose connection. You would think after 8 eye operations I could see better out of at least one eye Share this post Link to post Share on other sites
