HyperPete
36" Rototiller installation
HyperPete
I finally started installing the tiller on my 414.  I downloaded the manual(s), and physically attached it to the rear mount.
I do not have the lift cable & clevis, shown in the picture on the right.  It looks as if it has an adjuster built in, like a motorcycle throttle cable.
I have some jacketed stainless steel wire; do you think I can get away with that and a turnbuckle on back so I can get tilling?
Does anyone in the York, PA area have one they can sell me?  Does anyone know the length of the cable so I can have one made?
Many thanks, in advance!
HyperPete
Some tiller pictures, if it will help you help me,
and, what it's being installed on:
ineedanother
Hey Pete, I hope you're doing well. Lowell should be able to help you out with that. Those cables get a lot of stress but his cables and parts hold up pretty well. https://wheelhorsepartsandmore.com/product-category/cables/
HyperPete
Awesome, thanks - I need to till next week if possible!
Edited by HyperPete
HyperPete
Well, I got a reply from Lowell on Sunday; crickets since then.
I made a temporary cable but it's way too light duty.  It works with the spring adjuster cranked to max, but it won't last.  I'll go buy heavier cable and backyard engineer something since time is important.  I guess I'll need some shackles and clevis pins.
I don't know where to connect a spring on the front pulley (below the PTO) or what size spring.  The tiller owners manual is no help.  The parts manual is barely helpful.
Belt routing is also mysterious to me - it looks as if it will hit the floorboard.
Got the AGs & wheel weights mounted.  I need to paint the presently bare steel panels I put back on temporarily.  Lots of cleaning and painting are planned for this.
Edited by HyperPete
ineedanother
Hey Pete, this isn't a great picture but the spring on the "lever" for the idler pulley should run to a bolt that you need to put in the second hole in the frame. It will need to be a 3" or so bolt to serve as an anchor for the spring. The belts make a long run under the footrest to the tiller.
HyperPete
Perfect, thank you.  Now to try to source an appropriate spring.
Moparfanforever
Here is a closeup of the "older" style mid mount, if that is what you have. Hope it helps.
Moparfanforever
It does take a pretty stiff spring to keep tension on the arm for the pulley.
Edited by Moparfanforever
HyperPete
First, Lowell's wife called me this morning. They were dealing with the weekend backlog on Monday. I ended up ordering the entire rock shaft kit, and that will include everything I need. Yes I will have extras, but this is easier and less expensive than trying to source each part individually and paying shipping on them.
I also ordered a new belt just to be safe.
In the meantime, I scavenged a spring from a parts tractor that I have and set up the front pulley. See attached pictures. Something is obviously not right as the belts are hitting the support for the floorboards. This is with the tiller in the up position. I am going to go review the belt routing when I get home. Any suggestions are appreciated.
EDIT:  Reviewing @Moparfanforever's photo, I see at least part of my problem.  To be fixed...
Edited by HyperPete
