702854boy
C 100
702854boy
Posted (edited)
My uncle got a raider 10 that was swapped with a 12 horse and a c 100 that doesnt have a starter the other day. The raider 10 runs roght now so I don't need to tear into it yet but I do need to tear into the c100. The few things I've found that it needs so far are a starter, fuel tank grommet, and the flat idler pulley for the mule drive. Would anyone know where to get a grommet or have one that I could have? In exchange for working in it, I have gotten a free snowplow.
Edited by 702854boy
  • Like 6
702854boy
Here's some photos of it at the moment
gwest_ca
Have a local small engine repair shop that services tractors? The fuel tank grommet is one that most manufacturers use in their plastic tanks so has become a universal grommet.
Achto
C100guy94
Tractor supply will have them. In the bolt assortment area
702854boy
:text-welcomeconfetti:to the forum @C100guy94
702854boy
Posted (edited)
I took the shroud off the engine last night and it sure looked like mickey loved his home
It looks like this tractor was taken care of the most part until I presume either the starter went bad or the po got another tractor that needed a starter, the engine wasn't locked up, the mule drove wasn't locked up, the deck is locked up but probably just the old dried up grease needs cleaned out. Looking at the bottom of the steering shift and the axel it looks like it was greased on a regular basis.
Edited by 702854boy
702854boy
All the Kohler engines use a coil that needs no external resistor right?
pfrederi
Kohler wants a coil with an internal resister.  You can use a plain coil but need to add a ballast resister.
  • Excellent 3
Achto
Kohler coils have to have an internal resistor. One from a 1965 VW beetle will work if you have to get one from an auto parts store.
