Toolmanbill 44 #1 Posted April 28 Just purchased a 2001 314-8 with a kohler command pro 14.not sure about oil light being on when I turn the key on.is this normal?also can’t seem to find information on this motor using the serial number 1KHXS.3982GC. I think I should buy an oil pressure sensor just in case. I took this out and cleaned it and reinstalled it but it still works the same.any information would be appreciated. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,485 #2 Posted April 28 If the engine is not running and the light is on that is a bulb check. Should go out when the oil pressure builds. Engine owner manual and service manual https://www.wheelhorseforum.com/search/?q=ch14s-1838&quick=1&type=downloads_file Should be the illustrated parts list if your spec number is 1838 https://www.partstree.com/models/ch14-1838-kohler-command-pro-single-engine-made-for-toro-14hp Tractor operator manual 4 1 Share this post Link to post Share on other sites
