mas041
B-80 36" Deck Spindles Not Common?
mas041
I've been looking all over for just one deck spindle and side pulley after my spindle was bent or the bearing was shot. Either way, the actual spindle is damaged from removal. Pulley was rusted stuck so looking to replace that as well. I think its a 5-0621 deck but I'm not sure. The spindles don't quite line up with what I'm seeing online.
Anybody got a spindle for this?
ineedanother
I don't have a replacement for that but you should put an ad in the wanted section of the classifieds. I'm sure someone here has one.
gwest_ca
Welcome to Red Square
Mower spindle assemblies could be B, A1, G2 or Z
For A1 see service bulletin 292B
For G2 see service bulletin 292B
Click on the fuzzy picture in the link to download the 35 page manual
BradKahler
I believe this is the same shaft you're looking for, it is 4-1/2" long.  I received this from someone only to find out it was not a match for the shafts I was looking for.  The bearings are frozen but the shaft looks to be in ok condition.  You can have it for the cost of shipping if you think you can use it.  Shipping would be from Richmond KY.
953 nut
:WRS:
Looks like @BradKahler has you covered on the spindle, what is the diameter of the pulley you need? A post in our free classified section may get the job done.  https://www.wheelhorseforum.com/classifieds/wanted/
Brockport Bill
check K&B parts listed here as Vendor on tool bar - they have spindles
gwest_ca
You may want to replace with a newer version that uses blades with a 3/4" center hole. The D-hole blades are getting hard if not impossible to find.
  • Excellent 2
Lane Ranger
yes if the deck is still strong than moving to the upgraded spindle setup is a very good idea!
mas041
Sounds good Brad, I live in Richmond Va, so it's going from Richmond to the Richmond ha. I'll send you a PM to get the shipping set up.
mas041
7 hours ago, 953 nut said:
:WRS:
The pulley is roughly 3.25 inches in diameter. I'll check the classifieds
76c12091520h
Those shafts and bearings ( #103119 ) are all one piece , they are pressed into the housing.
76c12091520h
We do !
