mas041 1 #1 Posted April 27 I've been looking all over for just one deck spindle and side pulley after my spindle was bent or the bearing was shot. Either way, the actual spindle is damaged from removal. Pulley was rusted stuck so looking to replace that as well. I think its a 5-0621 deck but I'm not sure. The spindles don't quite line up with what I'm seeing online. Anybody got a spindle for this? Share this post Link to post Share on other sites
ineedanother 2,508 #2 Posted April 28 I don't have a replacement for that but you should put an ad in the wanted section of the classifieds. I'm sure someone here has one. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,304 #3 Posted April 28 Welcome to Red Square Mower spindle assemblies could be B, A1, G2 or Z For A1 see service bulletin 292B For G2 see service bulletin 292B Click on the fuzzy picture in the link to download the 35 page manual Share this post Link to post Share on other sites
BradKahler 340 #4 Posted April 28 I believe this is the same shaft you're looking for, it is 4-1/2" long. I received this from someone only to find out it was not a match for the shafts I was looking for. The bearings are frozen but the shaft looks to be in ok condition. You can have it for the cost of shipping if you think you can use it. Shipping would be from Richmond KY. 1 Share this post Link to post Share on other sites
953 nut 66,980 #5 Posted April 28 14 hours ago, mas041 said: looking all over for just one deck spindle and side pulley after my spindle was bent or the bearing was shot. Either way, the actual spindle is damaged from removal. Pulley was rusted stuck so looking to replace that as well. I think its a 5-0621 deck but I'm not sure. The spindles don't quite line up with what I'm seeing online. Looks like @BradKahler has you covered on the spindle, what is the diameter of the pulley you need? A post in our free classified section may get the job done. https://www.wheelhorseforum.com/classifieds/wanted/ Share this post Link to post Share on other sites
Brockport Bill 2,395 #6 Posted April 28 check K&B parts listed here as Vendor on tool bar - they have spindles 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,304 #7 Posted April 28 You may want to replace with a newer version that uses blades with a 3/4" center hole. The D-hole blades are getting hard if not impossible to find. 2 Share this post Link to post Share on other sites
Lane Ranger 12,004 #8 Posted April 28 11 minutes ago, gwest_ca said: You may want to replace with a newer version that uses blades with a 3/4" center hole. The D-hole blades are getting hard if not impossible to find. yes if the deck is still strong than moving to the upgraded spindle setup is a very good idea! Share this post Link to post Share on other sites
mas041 1 #9 Posted April 28 9 hours ago, BradKahler said: I believe this is the same shaft you're looking for, it is 4-1/2" long. I received this from someone only to find out it was not a match for the shafts I was looking for. The bearings are frozen but the shaft looks to be in ok condition. You can have it for the cost of shipping if you think you can use it. Shipping would be from Richmond KY. Sounds good Brad, I live in Richmond Va, so it's going from Richmond to the Richmond ha. I'll send you a PM to get the shipping set up. 1 Share this post Link to post Share on other sites
mas041 1 #10 Posted April 28 7 hours ago, 953 nut said: Looks like @BradKahler has you covered on the spindle, what is the diameter of the pulley you need? A post in our free classified section may get the job done. https://www.wheelhorseforum.com/classifieds/wanted/ The pulley is roughly 3.25 inches in diameter. I'll check the classifieds Share this post Link to post Share on other sites
76c12091520h 4,232 #11 Posted April 29 4 hours ago, mas041 said: Sounds good Brad, I live in Richmond Va, so it's going from Richmond to the Richmond ha. I'll send you a PM to get the shipping set up. Those shafts and bearings ( #103119 ) are all one piece , they are pressed into the housing. 1 1 Share this post Link to post Share on other sites
76c12091520h 4,232 #12 Posted April 29 8 hours ago, Brockport Bill said: check K&B parts listed here as Vendor on tool bar - they have spindles We do ! Share this post Link to post Share on other sites
