pfrederi
Real Confidence in their product
pfrederi
Bought  tubes for the Lawn Ranger fronts.  The came with patches....:wacko: also 2 plastic tools???   Anyone know what the are for exactly...I have lots of tire tools nothing like these two things...
  • Confused 4
rjg854
They sent patches with new tubes, makes one wonder :eusa-doh:
  • Haha 2
ebinmaine
Can't say for sure but those look quite a lot like bicycle tire tube installation tools I've seen in the past
ri702bill
Paul - do yourself a favor to avoid frustration.
Inflate the tubes to about 5 PSI a few days before you plan to install them. I lay each on a hard flat surface, put either a stout piece of cardboard or plywood on top. And a brick on top of that...
Take a tape measure to get a dimension from the top of the board to the hard surface below. Let it sit 2 days and remeasure. Verify they hold air....
Edited by ri702bill
pfrederi
Inflate the tubes to about 5 PSI a few days before you plan to install them. I lay each on a hard flat surface, put either a stout pice of cardboard or plywood on top. And a brick on top of that...
That is an excellent idea...mind the say every tube is "filled with air by the manufacturer for 48 hours test to ensure good air tightness"  yeah right...
New tubes that don't hold air...electronic parts that don't work out of box :wacko:
Edited by pfrederi
  • Sad 1
ri702bill
Ah, the "joy" of cost reduced consumer products made in the Offshore Facility. Methinks maybe they get seasick & upchuck in the shipping container on the way over...:blink:
ebinmaine
I've had tubes here that were new and had the rare custom ventilation slit by the valve.
I wasn't a fan of that setup so they got returned.
I know that's kinda fussy of me.
  • Haha 2
JoeM
top quality QC
  • Haha 4
953 nut
When I bought my A-60 @Achto and @WHX?? picked it up for me :text-thankyouyellow: and offered to put new tires on it for me.      :woohoo:     I bought the tires and tubes and had them shipped to Jim's address. He proceeded to mount them and when he inflated them both of the rear tires had bad NEW tubes, they split wide open. :scared-eek:
  • Sad 1
ri702bill
Merits repeating.
sqrlgtr
Its been a few years back but I went through several "new" tubes that were bad but have had pretty good luck since then. All the bad ones came from local tire shop, so I decided to start ordering my own and that's when my luck turned around.
:text-yeahthat:
Handy Don
8 hours ago, pfrederi said:
Definitely tire irons for helping slip the tire off of and then back onto a rim. Being plastic, they can slide along the rim with little risk of damaging it. The square notches at the near end are for adjusting the spokes on bicycle wheels!
WHX??
Yeah that was a real kick in the @$$ ... :sad-pacing:
  • Sad 1
