pfrederi 21,342 #1 Posted April 23 Bought tubes for the Lawn Ranger fronts. The came with patches.... also 2 plastic tools??? Anyone know what the are for exactly...I have lots of tire tools nothing like these two things... 4 Share this post Link to post Share on other sites
rjg854 13,454 #2 Posted April 23 They sent patches with new tubes, makes one wonder 1 2 Share this post Link to post Share on other sites
ebinmaine 81,281 #3 Posted April 23 Can't say for sure but those look quite a lot like bicycle tire tube installation tools I've seen in the past 3 1 Share this post Link to post Share on other sites
ri702bill 13,392 #4 Posted April 23 (edited) Paul - do yourself a favor to avoid frustration. Inflate the tubes to about 5 PSI a few days before you plan to install them. I lay each on a hard flat surface, put either a stout piece of cardboard or plywood on top. And a brick on top of that... Take a tape measure to get a dimension from the top of the board to the hard surface below. Let it sit 2 days and remeasure. Verify they hold air.... Edited April 23 by ri702bill 2 1 Share this post Link to post Share on other sites
pfrederi 21,342 #5 Posted April 23 (edited) 2 hours ago, ri702bill said: Paul - do yourself a favor to avoid frustration. Inflate the tubes to about 5 PSI a few days before you plan to install them. I lay each on a hard flat surface, put either a stout pice of cardboard or plywood on top. And a brick on top of that... Take a tape measure to get a dimension from the top of the board to the hard surface below. Let it sit 2 days and remeasure. Verify they hold air.... That is an excellent idea...mind the say every tube is "filled with air by the manufacturer for 48 hours test to ensure good air tightness" yeah right... New tubes that don't hold air...electronic parts that don't work out of box Edited April 23 by pfrederi 2 1 Share this post Link to post Share on other sites
ri702bill 13,392 #6 Posted April 23 Ah, the "joy" of cost reduced consumer products made in the Offshore Facility. Methinks maybe they get seasick & upchuck in the shipping container on the way over... 1 Share this post Link to post Share on other sites
ebinmaine 81,281 #7 Posted April 23 I've had tubes here that were new and had the rare custom ventilation slit by the valve. I wasn't a fan of that setup so they got returned. I know that's kinda fussy of me. 1 2 Share this post Link to post Share on other sites
953 nut 70,652 #9 Posted April 23 When I bought my A-60 @Achto and @WHX?? picked it up for me and offered to put new tires on it for me. I bought the tires and tubes and had them shipped to Jim's address. He proceeded to mount them and when he inflated them both of the rear tires had bad NEW tubes, they split wide open. 1 2 Share this post Link to post Share on other sites
ri702bill 13,392 #10 Posted April 23 Paul - do yourself a favor to avoid frustration. Merits repeating. Share this post Link to post Share on other sites
sqrlgtr 4,225 #11 Posted April 23 28 minutes ago, 953 nut said: both of the rear tires had bad NEW tubes, they split wide open. Its been a few years back but I went through several "new" tubes that were bad but have had pretty good luck since then. All the bad ones came from local tire shop, so I decided to start ordering my own and that's when my luck turned around. 6 hours ago, ri702bill said: Paul - do yourself a favor to avoid frustration. Inflate the tubes to about 5 PSI a few days before you plan to install them. I lay each on a hard flat surface, put either a stout piece of cardboard or plywood on top. And a brick on top of that... Take a tape measure to get a dimension from the top of the board to the hard surface below. Let it sit 2 days and remeasure. Verify they hold air.... 1 Share this post Link to post Share on other sites
Handy Don 17,735 #12 Posted April 24 8 hours ago, pfrederi said: Definitely tire irons for helping slip the tire off of and then back onto a rim. Being plastic, they can slide along the rim with little risk of damaging it. The square notches at the near end are for adjusting the spokes on bicycle wheels! 3 Share this post Link to post Share on other sites
WHX?? 58,388 #13 Posted April 24 1 hour ago, 953 nut said: they split wide open. Yeah that was a real kick in the @$$ ... 1 Share this post Link to post Share on other sites
