romain 1 #1 Posted April 6 Hello, I've lost the cable that connects the regulator to the carburator on my Kohler K181s 8hp engine (see pictures). Do you know where I might be able to find this piece, or get a 3D model so I can check the dimensions? Thanks in advance, Romain Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,505 #2 Posted April 6 Welcome to Red Square. This may be it. Click on the > arrow to roll it over. Those are likely 1" squares. https://www.partstree.com/parts/kohler-230078-s/ Share this post Link to post Share on other sites
Handy Don 17,546 #3 Posted April 6 On my K181 it measures 2-⅝” (2.625 inches) from outside to outside at the parts of the wire that pass through the governor arm and the throttle actuator. The wire is 5/64” (0.07812 inches) thick. 2 Share this post Link to post Share on other sites
sqrlgtr 4,077 #4 Posted April 6 @Handy Don got you covered on dimensions and an old Throttle cable is good to make one out of. Couple z bends and get close to the dimensions posted above and should be good to go. 1 Share this post Link to post Share on other sites
romain 1 #5 Posted April 7 Great, thank you for this valuable information ! 1 Share this post Link to post Share on other sites
