jsp_333 306 #1 Posted April 3 Putting the snowblower (79360) away and doing some year end maintenance. There is a collar on the drive shaft on the right side that has come loose. I'm assuming it goes tight to the body of the blower tight to the flange that has the grease zerk in it. I'm also assuming it's held in place by set screws. I've never seen a collar with 2 set screws before. One has fallen out and the other I can't seem to find the right allen key for. What have I got wrong? Is it in fact a collar or does it do something else? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,488 #2 Posted April 3 Does it have a counterbore on the back side to fit over the inner race of the bearing? If so it is a cam lock to secure the inner race to the shaft. One hole is for a punch so you can tap the collar to tighten against the matching cam of the inner race. You drive the collar in the direction of normal shaft rotation and lock it down with the set screw. Hard to explain. 1 Share this post Link to post Share on other sites
lynnmor 9,041 #3 Posted April 3 Here is one video showing the lock: 2 Share this post Link to post Share on other sites
WHX?? 58,156 #4 Posted April 3 (edited) 48 minutes ago, gwest_ca said: Does it have a counterbore on the back side It appears it does. One of the holes won't be threaded. A blind hole. Use the manual below to reset it. Clean excess grease off first. Toro Technician Tips Eccentric Collar quality_tips_june.pdf Edited April 3 by WHX?? 1 Share this post Link to post Share on other sites
WHX?? 58,156 #5 Posted April 3 1 hour ago, jsp_333 said: I can't seem to find the right allen key for. Replace the set screw regardless. 1 Share this post Link to post Share on other sites
jsp_333 306 #6 Posted April 3 (edited) Wow. Never cease to be amazed at the factual information available here. I'm going out to take a stab at this. I'll report back shortly. Obviously THANKS ALL! 99% successful. I could get the eccentric collar hand tight but every time I tried the punch it came loose. So I'm going to leave it as is with the set screw in place properly (I'll get a new one in there before next winter.) Unless there's some trick to smackin it with hammer. Edited April 3 by jsp_333 update progress 2 Share this post Link to post Share on other sites
lynnmor 9,041 #7 Posted April 3 4 hours ago, jsp_333 said: Wow. Never cease to be amazed at the factual information available here. I'm going out to take a stab at this. I'll report back shortly. Obviously THANKS ALL! 99% successful. I could get the eccentric collar hand tight but every time I tried the punch it came loose. So I'm going to leave it as is with the set screw in place properly (I'll get a new one in there before next winter.) Unless there's some trick to smackin it with hammer. The purpose of the collar is to make the bearing a tight fit on the shaft, it appears that yours has been run for a long time with the bearing wobbling and wearing the shaft. Start by cleaning everything and then check the damage. You might be able to buy a new bearing at TSC, the shaft is something to post in the wanted section. Share this post Link to post Share on other sites
oldlineman 1,809 #8 Posted April 4 yes a locking collar for the bearing, very common on farm equipment and other equipment. Share this post Link to post Share on other sites
jsp_333 306 #9 Posted April 12 I'll clean everything and take another stab with the punch. When turning it "hand tight" what is it tightening to? What exactly is the collar locking on to? I don't see anything resembling a thread on the counterbore or the bearing. Also in the image below it appears that the eccentric collar is sandwiched between two flanges and mine obviously is not. Am I just reading the image wrong. Share this post Link to post Share on other sites
oldlineman 1,809 #10 Posted April 12 the coller is locking onto the bearing flange ( the lip that protrudes from the center of the bearing) , that locks the bearing to the shaft. 1 Share this post Link to post Share on other sites
