Phan
Muffle remove
Phan
Hello, Happy Spring!
Could you please advise should I remove the connecting muffler pipe from B100. I want to use it on WH12 NO Name? Any risks/concerns? Thank you!
ri702bill
Since they are all simple black iron pipe components that are readily available, why not just go with new pieces??
  • Excellent 4
rmaynard
Since those three pieces now cost about $16.00 here in the U.S., he might be wanting to save a couple bucks.
ri702bill
But is it really worth the aggrevation to remove the fittings & you usually need to crush the block nipple anyway to get it out. All the carbon packs the NPT threads for a "lifetime" fit... I would think that inch sized pipe & fittings would be available up there ...
  • Excellent 2
Phan
I may be able to them fine from a local store - do I need any glue or just tighten the pipe to the engine?
Phan
I want to install a round muffler out directly from the engine - however, I'm afraid to damage the engine when removing process
https://www.amazon.ca/cart/smart-wagon?newItems=eb9b2ef2-8796-48de-aff0-976d72693e28,1&ref_=sw_refresh
ri702bill
No glue required! Just a pipe wrench. Those are tapered threads that "lock" when tightened...
oldlineman
That's what I was thinking, I would buy new and not take the chance of damaging the old block if you were going to save it.
Lee1977
After been on there around 50 years. it's not likely they are coming apart  without damage to the block.
  • Like 4
sqrlgtr
If you're wanting to plumb the motor in 2nd pic I would defiantly just go back with new. If you're trying to remove from top pic motor and use on 2nd pic motor the juice is defiantly not worth the squeeze :D.
gwest_ca
See if you can find an electrical conduit lock nut to add to the fitting before you install it into the block. Install the fitting as far as it will go into the block and then back it out at least 1/2 a turn so the fitting is loose. Using a hammer and punch now tighten the lock nut against the block. Fitting is now tight. If you remove using the reverse sequence once a year it will likely never be seized again. I always apply graphite to the threads as it seems to help.
What the lock nuts look like available from Home Depot or the like. They are available for all common pipe sizes.
This is a procedure I learned from a small engine repair shop that serviced thousands of small engines a year. It was part of their regular service.
  • Excellent 2
953 nut
Not all electrical conduit lock nuts are the same, be sure to ask for a RIDGID CONDUIT LOCK NUT. Many of the lock nuts sold at big box stores are for EMT fittings and will not work well, go to an electrical supply house.
