Phan 50 #1 Posted 8 hours ago Hello, Happy Spring! Could you please advise should I remove the connecting muffler pipe from B100. I want to use it on WH12 NO Name? Any risks/concerns? Thank you! PXL_20260329_211507024_TS.mp4 Share this post Link to post Share on other sites
ri702bill 11,544 #2 Posted 8 hours ago Since they are all simple black iron pipe components that are readily available, why not just go with new pieces?? 4 Share this post Link to post Share on other sites
rmaynard 16,988 #3 Posted 8 hours ago Since those three pieces now cost about $16.00 here in the U.S., he might be wanting to save a couple bucks. 1 Share this post Link to post Share on other sites
ri702bill 11,544 #4 Posted 6 hours ago 1 hour ago, rmaynard said: Since those three pieces now cost about $16.00 here in the U.S., he might be wanting to save a couple bucks. But is it really worth the aggrevation to remove the fittings & you usually need to crush the block nipple anyway to get it out. All the carbon packs the NPT threads for a "lifetime" fit... I would think that inch sized pipe & fittings would be available up there ... 3 2 Share this post Link to post Share on other sites
Phan 50 #5 Posted 5 hours ago 2 hours ago, ri702bill said: Since they are all simple black iron pipe components that are readily available, why not just go with new pieces?? I may be able to them fine from a local store - do I need any glue or just tighten the pipe to the engine? Share this post Link to post Share on other sites
Phan 50 #6 Posted 5 hours ago 1 hour ago, ri702bill said: But is it really worth the aggrevation to remove the fittings & you usually need to crush the block nipple anyway to get it out. All the carbon packs the NPT threads for a "lifetime" fit... I would think that inch sized pipe & fittings would be available up there ... I want to install a round muffler out directly from the engine - however, I'm afraid to damage the engine when removing process https://www.amazon.ca/cart/smart-wagon?newItems=eb9b2ef2-8796-48de-aff0-976d72693e28,1&ref_=sw_refresh Share this post Link to post Share on other sites
ri702bill 11,544 #7 Posted 5 hours ago No glue required! Just a pipe wrench. Those are tapered threads that "lock" when tightened... 2 Share this post Link to post Share on other sites
oldlineman 1,658 #8 Posted 3 hours ago That's what I was thinking, I would buy new and not take the chance of damaging the old block if you were going to save it. 2 Share this post Link to post Share on other sites
Lee1977 7,625 #9 Posted 3 hours ago After been on there around 50 years. it's not likely they are coming apart without damage to the block. 4 Share this post Link to post Share on other sites
sqrlgtr 2,308 #10 Posted 1 hour ago 3 hours ago, Phan said: I want to install a round muffler out directly from the engine - however, I'm afraid to damage the engine when removing process If you're wanting to plumb the motor in 2nd pic I would defiantly just go back with new. If you're trying to remove from top pic motor and use on 2nd pic motor the juice is defiantly not worth the squeeze . Share this post Link to post Share on other sites
