dsmreaper
Transaxle swap for a 1077
dsmreaper
Hello, just asking for a project I wanted to try and accomplish. What options does one have to swap from a hydro to a manual transaxle on a 67 1077. Are there bolt on options or will frame mods need to be done,if anyone knows. What are some good and strong manual transaxles.
ebinmaine
Because of the fact that the controls are contained in the sheet metal which is the steering tower and base, you really are better off finding a manual tractor. It's not just about swapping transmissions. You also need all the linkage, sheet metal, etc.
Possible? Definitely.
But there are easier ways to get a manual transmission.....
oliver2-44
The 3,4,6,8 speed transmissions will bolt right up. You will need a different belt guard or modify some fingers to slack the belt.  The 8 pinion 8 speed with 1-18”axles is the strongest WH transmission
dsmreaper
Thanks, I don't mind modding and fabing, I'm gonna make an off roader out of it, a cross between a tractor and an atv basically. I already knew a lot of control changes and cutting and welding will need to be done. I may even, in the long run, swap to independent suspension front and rear.
dsmreaper
Do you have a part number or brand name for they 8 speed you mentioned handy?
stevasaurus
A #5091 will do you nicely.  8 speed with 1 1/8" axles.  Common in a lot of the late 60's and 70's horses.  :occasion-xmas:
